86 Berlinetta v-6 stick to 305 auto turbo350 ...not shifting right.....
Old Aug 6, 2002 | 01:22 AM
barbiek9's Avatar
Angry 86 Berlinetta v-6 stick to 305 auto turbo350 ...not shifting right.....
My 86 Berlinetta v-6 was a steal @ $500, and I gutted her, put in a 305 h.o.,holley mech. 7lb fuel pump, carter 500 cfm carb, headers, accel super coil, 440 lift/260 dur cam, blah blah blah. Custom cut driveshaft to fit turbo 350 tranny, and she goes like hell until 70 km/hr, but then no more shifting. I checked the vacuum, every possible thing, but nothing. I can't get a straight answer as to what gears came in a manual trans 86 berlinetta v-6 (2.8 liter)... does anyone know if it's the gear ratio, or is this just some kind of satanic curse? I'm getting pretty annoyed, and would REALLY like to know what to fix. The tranny is good, I have all forward and reverse gears, but the shift timing is just WRONG, so I can only assume it's gears, but want to be sure before I rip everything out again. Thanx for any help u can give.
Old Aug 6, 2002 | 07:06 AM
kmook's Avatar
Advanced Tech Moderator
Post
Welcome to the board barbiek9.
This would be a little better suited for out 3rd Gen Tech section. I will move it there for you. If after a while (ie- couple days) you dont get many replies you can come back and try here.
Thanks,
Ken.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
Collector Car
Jan 5, 2015 10:58 AM
DropTop91
22
Aug 8, 2002 10:53 AM
