Opti on a SBC
Old Mar 11, 2005 | 06:21 PM
  #16
Bone Daddy's Avatar
Re: Opti on a SBC
Originally Posted by andy katzelis
When you said you use the baseplate and sensor do you mean the 360 holed wheel and sensor, just ditched the housing. What did you use for spark distribution? Looking at the opti page it seems like the sensor and wheel could be put in a distributor.....
Yup, the high and low resolution sensor are on a machined plate with a machined billet cover. Kind of looks like those covered plates they have when you eat in a hospital room.
For spark, I use a system similar to the LTCC. I threaded 8 holes in my valve covers and attached the coils there. I think it looks trick.
I agree that if you were so inclined, you could probably fit both sensors in a distributor. One of the problems is, you'd have to have a "normal" cam ground so that it had the dissy gear, and the LT1 nose. There would be some slack in the system, but you could probably tweak it out with a little tuning. And spark, that's another thing.. you would need to decide how to get spark to the cylinders. If you went the LTCC route, your holes on top of the dissy would be pretty much useless, and the cap just a cover. It would work, but it would look bad, and would have to be moisture sealed.
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
