oil filter bypass
oil filter bypass
do you really need the oil filter bypass in the oil pan if your oil filter has its own bypass built in
the ls3 pans have a threaded oil filter bypass inside the oil pan and also they use a pf48 or equivelent that has its own oil filter bypass built in
you dont like ac delco filters?, all the pf 48 equivelent filters have the bypass built into them
all the new gen 4 engines call for this filter, the thread pitch is different than the gen 3 engines
so if the filter has its own built in bypass would you still need the one that is screwed into the oil pan
WIX
Part Number: 57060
UPC Number: 765809570603
Principal Application: Various GM, Saturn, Saab (07-09)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 15
Anti-Drain Back Valve: Yes
Beta Ratio: 2/75=10/25
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
WIX
Part Number: 57060
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Jul 4, 2005 05:00 PM
