New valve guides??
Old Aug 11, 2006 | 09:43 AM
VK's Avatar
VK
New valve guides??
I need new valve guides, valves are coming out hard all the way (needed hammer to get valves out) and have wear marks on the stem.
Stock heads with new Stainless steel polished valves coming, so all i need is new valve guides.
Is there another place to get them besides Jegs and Summit?
Old Aug 11, 2006 | 01:19 PM
1racerdude's Avatar
Re: New valve guides??
Are your valves beat over on the ends?
Ya will have to take them to a shop to have the guides replaced so let them furnish the correct guides.
Old Aug 11, 2006 | 08:31 PM
MachinistOne's Avatar
They are coming out with a hammer because you did not file the keeper groove edge, you always need to do that.
Old Aug 12, 2006 | 07:09 AM
SStrokerAce's Avatar
Yeah, when your locks eat into your keeper groove it will cause this too happen. It's a sign of valve bounce or very high spring loads. The better valves come with radius groove or bead lock keeper groves that prevent most of this from happening.
Bret
Old Aug 15, 2006 | 09:48 AM
VK's Avatar
VK
I'm getting Manley Race-Flo valves (16) today, with CC 7* hardend locks and retainers. Then sending heads in if valves fit tight to get honed and maybe new valve guides. Am i going to need anyother prep work for the valvetrain before putting it back together?
Like the filing thing?
I know i need to do the correct spring installed height and seat pressure.
I'm using the GMPP LT4 Hotcam springs btw w/ the LT4 hotcam and CC 1.6 alum RR, NSA w/ guideplates and hardend pushrods (stock length)
Anything else i should know? do?
THANKS!!
Old Aug 15, 2006 | 10:31 AM
jerminator96's Avatar
I would go ahead a get some new guides, when you use the "removal by hammer" method, you can't really trust correlating parts. Could be wrong though.
Get some Beryllium Copper guides, I hear they work great. (Good neutron deflection properties as well )
Old Aug 15, 2006 | 10:52 AM
VK's Avatar
VK
Well, i got the new valves, and they fit perfectly!? .. so i guess my guides are fine and the valves are the ones messed up? Should i just install the new valves with original guides? or should i put new ones in?
Old Aug 15, 2006 | 11:29 AM
WS6T3RROR's Avatar
take it to a shop and have the stem/guide clearance checked out and make sure its right, and while you're there get a valve job too.
Old Aug 15, 2006 | 07:43 PM
When you pulled/hammered the valves out, you put lines in the guide which is an easy path for oil into the port.
Just because the valves fit does not mean the clearance is correct. Most likely you need to have the guides replaced or bronze liners installed. Then the seats need to be re-shot. Depending on how many miles you have on the motor, the exhaust seats might be pitted too, which means that even if the clearances are ok, the seats need to be shot. Take them to a shop and have them checked out.
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
gelbza
Jul 12, 2015 08:10 AM
