New Type of Engine Design
Old Jun 14, 2007 | 11:41 AM
95 Z/28 LT1's Avatar
Super Moderator
Anyone ever seen/heard of this? http://www.nevisengine.com/
Interesting concept. I wonder how long it will be before this catches on, or if it ever will. What's the downside?
Old Jun 14, 2007 | 12:33 PM
camz28aro's Avatar
looks interesting, I want to see a video of it working but IMO it won't catch on.
Old Jun 14, 2007 | 02:24 PM
jerminator96's Avatar
It looks pretty neat. The principles of it's operation seem to be solid. My major area of concern would be the amount of surface area in the combustion chamber. I was having a hard time seeing where everything went though, so maybe it's not as bad as it appears.
Old Jun 14, 2007 | 02:43 PM
thesoundandthefury's Avatar
250HP@2,000rpm's out of 2 cylinders.
"However, as can be inferred from the table above, the NEVIS engine could run at nearly 3 times this level of rpms, yielding still more power – approximately 500HP"
Meh, it's okay I guess...
Old Jun 15, 2007 | 12:34 PM
blue89rs's Avatar
250hp at 2000rpm would mean 656ft.lbs. of torque. whoa. I've seen engines similar to this that use multiple pistons on a sort of carnival ride looking deal. The pistons rotate on a drum of sorts around the "crank". Both the Nevis and the before mentioned rely heavily on a wave patterned piston guide cut in the sidewall. Seems to be a weak point.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 27, 2015 06:27 AM
guionM
9
Aug 29, 2002 01:48 PM
dmaastr
9
Jul 1, 2002 02:22 PM
