New here and have a dry sump question
Old Jun 15, 2005 | 01:02 AM
99PewterTA's Avatar
New member and have a question reguarding a dry sump system.
I have plans in the works for a forged/Billet bottom end ls1 with about a 9.1:1 CR and im looking at cranking 20+lbs of boost into it through a twin turbo setup, I am trying to locate a dry sump system to handle the oiling needs of both the engine and the turbo's as they will be generating a lot of heat.
I think I am going to be needing a 3-4 stage Dry sump system to supply the needed flow and presures demanded by the engine and turbo setup. any help with what I should be looking at for the lube system would be appreaciated. thank you.
Rob
Old Jun 15, 2005 | 01:11 AM
MachinistOne's Avatar
Re: New here and have a dry sump question
Weaver Bro's is the company we have used with success on our race motors...
Weaver Brothers, LTD.
1980 Boeing Way
Carson City, NV 89706
(775) 883-7677 Phone
(775) 883-6413 Fax
Our Email Address is: oilpumps@weaverbrothers.com
http://www.weaverbrothers.com/
Old Jun 15, 2005 | 07:04 AM
OldSStroker's Avatar
The dry sump pans I've seen on LS1 engines were in the Daytona Prototype (DP) racers. Just looked at some of the engines this weekend at Watkins Glen. The pans were billet aluminum pieces. I suspect they are available if you search enough. That surely wold be cheaper (but not cheap!) than designing and manufacturing you own. The bracketry for pumps should also be available.
Old Jun 15, 2005 | 09:19 AM
99PewterTA's Avatar
1980 Boeing Way
(775) 883-6413 Fax
thanks I sent them an e-mail. I have seen dry sump oil pans but as of right now I want to try and find a bolt up kit if they are out there if not then im going to get a custom setup that will work for exactly what I am needing, thanks for the reply's
Old Jun 15, 2005 | 09:00 PM
turb0racing's Avatar
Look into the circle track market for a 3 stage pump and all the brackets. You might not be able to buy as a kit but i know you can piece the parts together. I did a quick search and found this.
http://www.stockcarproducts.com/oilsys.htm
If you plan to pump that much boost then a lower cr might be a good idea.
Old Jun 15, 2005 | 10:31 PM
99PewterTA's Avatar
lower than a 9.1:1? i thought that was quite low already what CR should i run with 20+ lbs
Old Jun 18, 2005 | 04:14 AM
Eric G's Avatar
9.1:1 isnt low at all, maby for NA. Thats high for the boost your talking about running.
I would want to be running 8:1 or so if I was planning on 20+ Pounds of boost, rskrause is running 7.8:1 I think?
Old Jun 18, 2005 | 04:43 AM
TheNovaMan's Avatar
Anybody use Aviaid?
Old Jun 19, 2005 | 10:31 PM
99PewterTA's Avatar
thats good to know about the CR i was thinking that at the 9.1 it would be good, glad i found out before i blew my self up.
Old Jun 20, 2005 | 04:41 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
let your motor builder (hopefully somebody with lots of experience doing what you are doing) decide. 9:1 is not high, nor low. it depends on what you are doing exactly.
I know of a certain LT1 that ran 11:1 and 20psi for several seasons with out an engine failure.
Old Jun 20, 2005 | 10:19 PM
dkeers's Avatar
Check out Armstrong Race Engineering at http://www.drysump.com/index1.htm
They have a complete LS1 kit. He makes sumps for the prototype cars. I have never used their LS1 kit, but we use the SBC sumps and I saw the LS1 sump at the PRI show and it is a very nice piece. They are very good to work with.
Dustin
Old Jun 20, 2005 | 10:35 PM
SStrokerAce's Avatar
Agreed....
Also check out these guys... http://www.petersonfluidsys.com/index.html
They have a hell of a good customer list.
Old Jun 21, 2005 | 03:03 AM
99PewterTA's Avatar
im going to be doing a lot of the work my self but im working with a guy who used to be a lingenfelter tech, so he should know about twin turbo lsX engines.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 26, 2015 08:34 AM
jasonduaine
Mar 7, 2015 09:44 AM
Fatdog2
Feb 13, 2015 08:19 PM
