Need Help with Ignition key cylinder
Old Dec 10, 2003 | 09:11 AM
gogi's Avatar
Hi all,
Hope someone could help me! I have a 96 z28 and I am changing the ignition key cylender the whole unit since I dont have keys. The VIN does not help because the lock was changed prior so the key cut does not fit.
So If I buy a ignition cylinder with new keys and the Chip do I need to take the car to the dealership so that they reset the computer? If so is there a way arround it?
Thx Guys very much!!!
Gogi
Old Dec 10, 2003 | 12:05 PM
marshall93z's Avatar
why would you need to reset the computer?
i put a new cylinder in mine and then started it and drove off...
Old Dec 10, 2003 | 12:19 PM
gogi's Avatar
I heard that you have to reset it because of the chip in the key. So that the computer can program the resistance again?
Do you know about this?
Old Dec 11, 2003 | 03:06 PM
Routine tech and maintenance questions should be posted on the appropriate "generation" board... in this case "LT1 Tech". It does not belong on Advanced Tech.
Dzmaro
Jan 25, 2015 10:39 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
phil46y
Jul 20, 2002 12:58 PM
