Need Help ASAP
Old Aug 23, 2002 | 08:18 PM
TazZ28's Avatar
Post Need Help ASAP
I am still in the test phase of my car. It doesnt break up at all but when I am at WOT the car pauses for a second, it is like you hit the kill switch and turned it right back on and then it has all the power again. I am not losing anything electric it seems like it isnt getting spark or fuel for a split second.
has anyone seen this problem before ?
Please give me your advice. i do know that I am running lean on one injector Replacing that tomorrow but I dont think that would be the problem.
Thanks in advance
Car specs it is a 1996 396 stroker with 18lbs of boost. Fast System
Old Aug 23, 2002 | 11:06 PM
Z-OwNEr's Avatar
Post
Off topic, what kind of number are you seeing with you setup?
Old Aug 23, 2002 | 11:51 PM
camcojb's Avatar
Post
What size injectors are you running and what's the duty cycle? Are you running the car with the gas tank fairly low? When the duty cycle is too high or accelerating hard and the pickup in the tank gets uncovered you can have symptoms like you describe. Also rev limiters, etc. If it's a fuel delivery problem (tank baffling, too small of injectors, fuel pressure, etc.) it should show up in the duty cycle.
Jody
MY CAMARO
Old Aug 24, 2002 | 12:53 AM
TazZ28's Avatar
Post
680 at the rear so far.
83 lb inj with a full tank of gas have to large pumps controller controlled. 45lbs of pressure
will have to check duty cycle.
Old Aug 24, 2002 | 10:51 AM
znines's Avatar
Smile
Check in your FAST program in the MAP AE with a boosted application you dont want any more than about 120. This is basiclly your accelerator pump in FI . Any higher than that and it will experience that symptom.
Off The Bottle Under Pressure!
www.ssracing.net
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
