Need cam help
Old Jan 14, 2005 | 09:25 PM
lt1zpwr's Avatar
Need cam help
which cam can i get, i have a 96z 6 speed and i want a cam that has nice sound can give me a lil power and also will pass emissions. if i get a radical cam and get a pcm tune will this allow me to pass emission ( at mine all they do is check gas cap and plug this thing inside the car and i think if there are no pcm codes u pass ). i was considering the lt4 hot cam ang suggestions? thanx
Old Jan 15, 2005 | 01:02 AM
lt1camaroman93's Avatar
Re: Need cam help
You may want to post this in the LT1 forum...
Old Jan 15, 2005 | 05:49 PM
lt1zpwr's Avatar
Re: Need cam help
i figued sincd it has to do with engine componets in general it should be hear
Old Jan 15, 2005 | 05:58 PM
OldSStroker's Avatar
Re: Need cam help
You might read this. It's at the top of Advanced Tech.
http://web.camaross.com/forums/showthread.php?t=47092
You'll get lots more reads and more suggestions on LT1 Tech as was noted.
Suggestion: Spend a little time searching for similar "What Cam do I need" posts in LT1. All you need to know is there.
Good luck!
Old Jan 15, 2005 | 07:25 PM
lt1zpwr's Avatar
Re: Need cam help
thanx man my bad
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
