Mystery injectors???
Old Jul 22, 2002 | 03:40 PM
Perry93TransAm's Avatar
Post Mystery injectors???
I have a set of injectors off of a 89 or 90 Thunderbird S/C (yes I have 8 even though it was a 6 cylender) They are red tops with the following #s E9SE-B1B on one side and 0280150756 on the other, two of them are odd ***** with red tops but the following #s FOSE-85A and 0280150941 on the other side.
The guy I bought them from removed them and went to a FP performance high impedance set-up with big injectors, hence he now has no use for these, he said they were 32#ers but wasnt sure as his car ran lean until he bumped the pressure on it up to 50 PSI ( 86 T/A) So does anybody know what these creatures are?
Perry
Old Jul 23, 2002 | 11:17 AM
rskrause's Avatar
Moderator
Post
I would have them flowed before using them, especially since they have different part numbers.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Jul 23, 2002 | 02:38 PM
Post
I plan on having them cleaned and blueprinted, *Update* I found out what they are, ford calls them a 30 # injector, the second part # I have is the service replacement for them. They originally came on the 90 to 93 Thunderbird S/C (3.8 supercharged). Thanks Rick for your response.
Perry
Old Jul 24, 2002 | 02:02 PM
madwolf's Avatar
Post
0 280 150 756 321cm3/min (31.0 LBS/HR) (3.0 bar)(43.5 PSI)? FORD 3.8L S/C V6/GM Truck 4.3L V6 Turbo
0 280 150 756 331cm3/min (32.0 LBS/HR) (3.1 bar)(45.0 PSI)? FORD 3.8L S/C V6/GM Truck 4.3L V6 Turbo
Old Jul 24, 2002 | 02:38 PM
Post
Thanks madwolf, that info you have there is more indepth than what I have found earlier. So actually they both are slightly different. I may have to go buy 2 to replace the oddballs. Thanks. Oh in my first post I meant he got a low impedance system, my bad.
Perry
Old Jul 24, 2002 | 03:25 PM
madwolf's Avatar
Post
Perry, not sure about the oddballs, but I wouldn't use them.
Here's the only thing I could find:
FORD 1.9L/2.3L(IC-078)
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
