Motor Mounts
Old Oct 19, 2003 | 02:34 PM
TTLYNTS's Avatar
Motor Mounts
Okay...i'm trying find some motor mounts that i can use to put a 400sbc in my 96Z. This is going to be a drag only car which will be carb'd. I spoke with PA racing and it will be several months before they offer the k-member with the sbc mounts again. Does anyone else know of someone that makes these? I'll be content using my stock crossmember for now if i can find the correct mounts.
thanks....Rusty
Old Oct 19, 2003 | 05:14 PM
got_hp?'s Avatar
couldnt you just buy some aftermarket motor mounts that fit your engine (probably cheap at summit or jegs).........then weld them into place on the existing k-member?
Old Oct 20, 2003 | 10:11 PM
stroked383z28's Avatar
I'd like to know the answer to this also. I'm about to start a similar project and would like to know where I could get a drop in solution.
Old Oct 22, 2003 | 04:20 PM
KTamez's Avatar
Call Pete Zawadski at Apple Tree Race Cars. (315)483-6412
Ask for his Tubular Engine Mounts for LT1 F-Bodies. They will bolt directly to either an LT1 or Gen1 SBC.
Old Oct 22, 2003 | 05:25 PM
TTLYNTS's Avatar
thanks very much....i'll give him a call in the am.
....Rusty
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
