measuring crank throw? 355 vs 383
ok I have what the shop told me is a 383 stroker crank BUT it has 383 and 355 punched into it
So I measured it but i really don`t know how. This is how I did it, I measured from the center of the main journal to the top of the rod journal and it came out around 3.5" which to me says it`s a 350 crank because 350 cranks are 3.48", so did I do it wrong or is this crank a 350 and NOT a 3.75" 383 crank????
Please help,
Note: I read the notice about this tech page and it said stroker motors so I thought my question should go here, Sorry if I`m wrong this is the 1st time I`ve posted in here.
Please help, Note: I read the notice about this tech page and it said stroker motors so I thought my question should go here, Sorry if I`m wrong this is the 1st time I`ve posted in here.
Re: measuring crank throw? 355 vs 383
Please help,
Example: 7.0 inches top measurement and 2-15/32 lower measurement.
7.00 - 2.47 - 1.05 = 3.48. Or 7.0 top and 2-3/16 lower give 7.00 - 2.19 - 1.05 = 3.76 which would be a 383 crank.
I can't get 3.5 inches on either crank the way you described.
Originally Posted by Bills77
depending on the cranks manufactuer, sometimes it will have the stroke on it. both my eagle cranks have 383 on them.....
So I guess I measured it wrong, I just took a tape measure and put it 1/2 up the main journal and measured at the top of the rod journal which was a tick below 3.5"
My crank which is a scat, has BOTH 383 AND 355 stamped on it
Measure center of main to center of rod journals and multiply that X 2
Drtryder
Apr 22, 2015 04:17 PM
