major engine problems
Old Aug 23, 2005 | 05:49 PM
1986iroc_z's Avatar
freshly built 305 blowing gas out top of carb any ideas why.timing compression all are perfect and i have checked the heads for bent valves all are good as well as push rods and the cam is working fine.i do not know if the cam is too big since i did not put this engine together but i doubt it is .if anyone has any ideas please share this is my last option
Old Aug 23, 2005 | 06:06 PM
1racerdude's Avatar
Re: major engine problems
When is it blowing it out or is it coming out of the bowl vent's?
Old Aug 23, 2005 | 07:22 PM
1986iroc_z's Avatar
it is coming out of the very top of the carb where it sucks the air in for the air/fuel ratio and i think it blows out when a cylinder compresses b/c it fluctuates from side to side
Old Aug 23, 2005 | 07:26 PM
1racerdude's Avatar
Is it blowing out at idle? If so my guess is the valves are to tight.
Old Aug 24, 2005 | 07:50 PM
1986iroc_z's Avatar
it is blowing out when i try to start it i havent even gotten it running yet but my lastest idea is that the timing may be half way out but i dont know yet i'll have to do the proper compression test on each cylinder first i wuill keep u posted
Old Aug 24, 2005 | 07:56 PM
stealthblack's Avatar
distributor a tooth off? maybe cam not degreed in properly?check lash? if its stock 86 balancer it could have slipped and is giving you a false TDC mark.
Old Aug 24, 2005 | 09:16 PM
Jerm93z28's Avatar
sounds like the dist. is 180 degrees out.
Old Aug 24, 2005 | 11:52 PM
WS6T3RROR's Avatar
yep sounds like shes out 180 to me too. put your #1 on tdc on the comp stroke and pull your dist cap, if it aint pointing at #1 take it out and flip it around. i would do that test before i spent the time on a comp test, because if thats the problem the comp test will show normal, and the motor still wont run.
cmdeshon
Jan 4, 2015 11:15 AM
Jazsun
Dec 29, 2014 12:14 PM
guionM
69
Nov 30, 2006 02:01 PM
