Lucas 42 lb/hr disc type injectors and 80 + PSI fuel pressure
Old Apr 21, 2004 | 04:10 PM
TriPinTaZ's Avatar
I have a set of Lucas/Delphi 42lbers from Racetronix.
I want to keep my dry N20 setup ( NOS5176) but have never tried it with hte new injectors and 383 stroker.
Does anyone know if these disc type injectors would not operate at the 80+ PSI the NOS kit send the fuel pressure to when spraying ?
Old Apr 21, 2004 | 06:57 PM
SMOKNZ's Avatar
I've operated mine upwards of 70 psi. Hadn't gone any higher though.
Old Apr 22, 2004 | 09:08 AM
mtxpert's Avatar
I was told by Jack not to run these at high pressure but I would be interested if anybody had went ahead and tried them at 90+PSI.
Mike
Old Apr 24, 2004 | 03:03 AM
Racetronix's Avatar
I don't think ANY hi-z injector should be run at 90PSI !!!
Old Apr 24, 2004 | 01:49 PM
TriPinTaZ's Avatar
so do you think my injectors would be ok at 75-80 PSI when i spray N20 ? or should i jsut get a wet kit
Old Apr 24, 2004 | 02:38 PM
Racetronix's Avatar
Get a wet kit.
They are easier to tune.
Less potential problems.
The N2O jet helps atomize the fuel.
Old Apr 25, 2004 | 03:23 AM
TriPinTaZ's Avatar
i understand it would be easier to tune, however the dry system is already installed and ready to go. I have the correct jets in already for the proper amount of fuel through the 42 lbers. i just want to make sure the disc type injectors would be ok at 75 PSI.
after the dyno if im unhappy then ill go to a wet kit. I just would rather spend the $1000 on something else than another N20 kit
Old Apr 25, 2004 | 03:30 AM
Racetronix's Avatar
Chances are you would be OK at 75PSI BUT ALWAYS keep an eye on the FP and A/F when tuning. Start with a small shot to make sure everything is OK before stepping it up.
Old Apr 25, 2004 | 08:18 AM
SMOKNZ's Avatar
All you would need for the wet kit is a fuel Noid and lines and a different nozzle. You already have the rest. Wouldn't be anywhere close to $1K
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
