Lube on threads.. does it increase torque accuracy?
Old Aug 11, 2006 | 12:20 PM
  #16
1racerdude's Avatar
Re: Lube on threads.. does it increase torque accuracy?
Originally Posted by oldBones
On Fords Modular motors the head studs/bolt dont go in to the water jackets.
Ya know the MM isn't the ONLY engine Ford makes. I have been doing Fords and GM since the '60's and they didn't have the MM then.
Old Aug 18, 2006 | 05:11 AM
  #17
jonathan_abilene's Avatar
Originally Posted by RBE17
Install per the manufacturer's recommendations. If you're unsure, call them, they have plenty of data to support their recommendations.
Good luck,
Steve.
I'm gonna call big time BS on this one... everytime I try to email or call GM
I dont get an answer or I get an "I dont know, let me get back to you".
However I believe the factory recommends SAE 30 on things like rod bolts. Torque it 3 times and that will put you real close. Of couse every bolt stretches differently.
Whenever the T2Y bolts have the fiber or nylon or whatever on them heres what I read:
http://www.engineparts.com/motorhead...iles/frame.htm
Friction Loss: 90% of the applied torque to a typical threaded joint is used to overcome friction
50% of the friction is between the threads of the fastener & threads in the block
50% is between the underside of head of the fastener and work
10% of applied torque actually stretches the fastener, applying force needed to load the joint
Thats alot of difference!
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
karpetcm
Aug 14, 2015 03:02 PM
