LTCC and still missing??
Old May 27, 2003 | 07:05 PM
Brady's Avatar
I just got the car back together with the LTCC, new wires, plugs and new valve springs. It still misses at high rpm, what are the odds of have a bad opti? It has 30k miles and is about 3 years old?
Does anyone have experience with this sort of thing??
thanks a bunch, I'm supposed to head out for the Power Tour Thursday!!
Old May 27, 2003 | 08:46 PM
kmook's Avatar
Advanced Tech Moderator
Hey Brady,
Is this under load, or stopped and reving, or both?
And have any kinds of logs by chance?
Old May 27, 2003 | 09:27 PM
Joes94TA's Avatar
prolly already checked into to but,brady its possible your blowing out the spark under boost..
Old May 27, 2003 | 09:35 PM
Brady's Avatar
It misses under load, it doesn't appear to do it when I just rev it freely. It doesn't just miss slightly either, it breaks up badly. It might have a miss below 3k too, but it's hard to tell if it's got a random misfire or if it's just the cam talking..
I don't think it's blowing the spark out, I have new autolite 103's gapped @ .028
Old May 27, 2003 | 10:08 PM
Joes94TA's Avatar
you read the plugs after its done it? could be mistaking a bad miss for detonation..plugs will tell the story... then again diagnosis over the internet is a crap shoot ...so I'm just throwing out ideas you may or may not have checked into..
Old May 28, 2003 | 03:02 AM
Kain's Avatar
Maybe one of your new coils is bad, I'd test them, and the plug's resistances too.
Old May 28, 2003 | 05:32 PM
JSK333's Avatar
Don't have much experience (ok, none) with boost, but... that gap seems awfully small, even for high boost.
Maybe it's breaking up/missing because the spark isn't "big" enough to fully ignite the mixture. An odd thought, but maybe you could try upping the gap to ~.035 and see what happens?
Old May 29, 2003 | 12:19 AM
Brady's Avatar
Thanks for the ideas, today I swapped out the opti for a known good opti and it helped drastically. My old opti sounded like it had rocks in it. I still have a miss though, but it *seems* like it may be a single cylinder miss rather than random misfire. I'm going to pull a couple coils off my '98 and throw them in the car along with the LT1 coil, and head out on the Power Tour.. F*ck it, if it breaks down, I have a trailer
wish me luck!
....Brady
Old May 29, 2003 | 02:21 PM
sleeperz28's Avatar
Brady I had a similar problem. Did you check to see if the LTCC is pulling any codes? If any spark plug wires are close to the opti wires it will cause a miss. I had to move all plug wires atleast 3in from the opti before it cleared my problem.
Good luck
Old May 30, 2003 | 01:01 PM
bunker's Avatar
Yeah check to see if you're pulling codes on the LTCC, could very well be your opti harness.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
