LT4 heads and rocker-girdles...
Old Aug 23, 2004 | 10:33 AM
cASe SenSiTive's Avatar
Exposed Member
It would appear that the LT4 heads don't accept a regular SBC rocker-girdle. Both of the ones I have on hand are "off" on the exhaust stud be a good bit.
What are you LT4 headed guys running? Part #s?
Thanks.
Old Aug 23, 2004 | 08:52 PM
DaveZLT1's Avatar
Re: LT4 heads and rocker-girdles...
Believe Madman sells one.
Old Aug 24, 2004 | 01:36 PM
Mindgame's Avatar
May want to check with Moroso.
Good luck.
-Mindgame
Old Aug 24, 2004 | 05:55 PM
ru2slo_99's Avatar
I have the Moroso girdles on my car, but I have lt1 heads. I didnt think the valve spacing was any different with the lt4 heads?
Old Aug 24, 2004 | 08:11 PM
Z8'S's Avatar
I run the Crane girdle on mine everything lined up fine
Old Aug 25, 2004 | 10:54 AM
Birdie2000's Avatar
I have AFR LT1 heads and my Jomar girdle fits fine.
Z8's, is that crane girdle for centerbolt valve covers?
Old Aug 25, 2004 | 05:45 PM
Z8'S's Avatar
No I have my heads setup for perimeter valvecovers
Old Aug 28, 2004 | 12:19 AM
SStrokerAce's Avatar
You can get a Comp undrilled one and then set it up exactly for your heads. Not bad when you have a mill on hand to get it done. The AFR (except 215 RR) valve centerline is tradtional SBC where the LT1/LT4 is like the bowtie valve centerline, so yeah you might have problems with finding the right stud girdle for the heads. IF the Moroso one works on LT1's it should work on LT4's
Chris I thought your car had AFR's on it?
Bret
Old Aug 28, 2004 | 10:22 AM
Z8'S's Avatar
Bret
I am still running GM LT 4 castings at this time ,But have a set of AFR's on the way should be on in the next couple of weeks. I think we have found the limits of the stock castings 8.92 e.t 159.84 mph.Gonna see what another 40 cfm will do
Old Aug 31, 2004 | 09:50 AM
Exposed Member
Hmmmmm... this may explain some things. Thanks guys.
Old Sep 9, 2004 | 10:39 PM
lillbush5555's Avatar
will this fit? If I drill out holes for the valve cover bolts?
http://cgi.ebay.com/ebaymotors/ws/eB...33624#Shipping
Matt
Old Sep 10, 2004 | 12:00 PM
Hot Rod Hawk's Avatar
Matt
NO it won't work.
he needs the vortec type
Old Sep 10, 2004 | 12:26 PM
whats the Vortec type?
Matt
Old Sep 12, 2004 | 10:59 PM
ru2slo_99's Avatar
That type will not work becuase the bolts that hold the two halves together are were you need to drill. The kind I have (Moroso) are the type that have U-bolts squeezing the poly-locks and they already have the hole cut in them. They were like $125 from Summit.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
