LT1 intake....siamese runners?
Old Jul 6, 2005 | 02:30 PM
  #16
WS6T3RROR's Avatar
Re: LT1 intake....siamese runners?
and as a side effect you're shortening the lt1's already too short runners. this is a really really bad idea imho. its right up there with making the runners in a vic jr siamesed. runner length and cross sectional area is a very critical piece of where you make your power at and how much you make because if effects the rpms you can run. just hogging out part of the divider and shortening the runner and would create very negative results if you ask me. tpi's benefit because they have a runer thats way too long and way too small. so you're not really hurting them when you knock down the length of a runner thats 13" long and then the siamesed runner acts like part of the plenum. but keep in mind theres still a good chunk of runner in the base manifold of those a good 6" or so.
Old Jul 6, 2005 | 06:49 PM
  #17
simple's Avatar
tis why i asked before trying
so then my other big "can o worms" question arises....
short of converting a carb style or going custom with the intake (including Steve Quinns hybrid type)
what ALL can be done too the LT1 intake on top of removing the injector ramp, porting and polishing the runners too get maximum potential out of it without needing unacceptable rpm (7000+) for a street motor?
time has gone by now since this intake has been available but has the wall of what can be done too it been scaled already?
btw, thanks for answering fellas
Old Jul 6, 2005 | 08:10 PM
  #18
OneFlyn95z28's Avatar
Hmmm.... The effect would be like makes the runners even shorter then they are and adding Plenum Volume.
That is my guess lets see what the big boys say
Old Jul 6, 2005 | 10:22 PM
  #19
SStrokerAce's Avatar
Well plain and simple... not enough. Throw more cubes under it and it all gets worse.
Bret
Old Jul 7, 2005 | 02:52 PM
  #20
Copying it didn't work... somebody moved the original from LT1 Engine Tech to "Advanced Tech"..... now we'll try the "merge" option, and delete the duplicates.
Old Jul 7, 2005 | 10:50 PM
  #21
Thanks Fred
rcajun86
Jan 30, 2015 01:56 PM
CARiD
Jan 27, 2015 06:27 AM
95chwagon
Jan 13, 2015 09:19 PM
Redbird
Sep 14, 2002 09:18 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
