LSA vs. horsepower
Old Aug 10, 2003 | 09:31 PM
marshall93z's Avatar
LSA vs. horsepower
i have heard different people say different things but i thought you guys would know more about it.
what does lsa do to the horsepower. from what i understand a tighter lsa will produce more horsepower. but i have also heard people say that they are going with 112 vs. 114 to keep the rpm's down. is this true too? that the tighter the lsa the quicker it will peak.
thanks for the info.
Old Aug 12, 2003 | 09:00 PM
im sure you guys know something about this stuff. come on now, enlighten me!
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: LSA vs. horsepower
check out a thread I started called "using LSA to adjust the powerband"
Rich explains all.
LSA should just "happen" as a result of propperly chosen cam events
Old Aug 12, 2003 | 10:28 PM
Zero_to_69's Avatar
A tighter Lobe separation means that the exhaust valve and intake
valve are both open for a longer period of time.
At low RPM or Idle, this will produce weak vacuum and poor idle
because the pistons are moving slower and cannot create a
low enough pressure area to suck in fuel/air mix.
For higher RPM, the tighter LSA will promote scavenging improving
volumetric efficiency. This of course only applies with properly tuned
intake, exhaust, etc.
Old Aug 13, 2003 | 09:45 AM
seems to me that alot of people disagree on some of the effects of lsa.
Old Aug 13, 2003 | 05:53 PM
OldSStroker's Avatar
Read all of that thread Trey started.
http://web.camaross.com/forums/showt...hreadid=120198
Rich's posts are very good.
In summary, when the engine designer chooses the intake and exhaust valve events to fit the engine's intended use and parts combinations, the LSA is what's left; it's not the place to start the cam design. IOW, it's a dependent variable.
Old Aug 13, 2003 | 08:46 PM
treyZ28's Avatar
if you want to "expierence" this first hand, try desktop dyno. I wouldn't trust it for accuracy of numbers (too many variables are missing for it to be accurate IMHO- but then again what do i know) but it seems to work well for cause and effect.
you also wont see a "durration" or "lsa" input anywhere. you will find a intake/exhuast opening closing and centerline input though further backing the "depenent" variable thoery
...maybe i should say experiment instead of expierence now that i think about it
Old Aug 15, 2003 | 12:58 AM
AdioSS's Avatar
West South Central Moderator
Trey, go to the button called Cam Math to put duration numbers in
95chwagon
Oct 16, 2015 12:24 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
