Looking fo SBC 5.850" Billet I-Beams...
Old Dec 14, 2008 | 05:58 PM
Boostwhat's Avatar
I need a set of 5.850" Billet I-Beams that can handle some serious abuse while not killing my budget. Anyone have any ideas? Derek
Old Dec 15, 2008 | 12:16 AM
Steve in Seattle's Avatar
1) How much is "serious"? (RPM, HP, power adder?)
2) what's the budget?
3) Does it HAVE to be billet?
Old Dec 15, 2008 | 10:43 AM
Boostwhat's Avatar
1) 2 systems 400+ Gas
2) Less than a Oliver ~$1200
3) 1000+ Hp so preferably billet
Old Dec 15, 2008 | 07:28 PM
rskrause's Avatar
Moderator
Aluminum is what you need.
Rich
Old Dec 16, 2008 | 08:07 AM
AdioSS's Avatar
West South Central Moderator
Rich
Hope it isn't a street engine...
Old Dec 16, 2008 | 03:16 PM
CreatiVe2's Avatar
just went with a set of 5.850 H beams forged from eagle. what power are you looking at? any particular reason for billet & I beam? also what is the displacement of the motor your putting them in? sounds pretty serious
Old Dec 16, 2008 | 03:25 PM
blue 79 Z/28's Avatar
he stated that already, id pick aluminum also if it was a track only car more insurance on the bottle. you can still get away with steel no problem a that point also. rpm dependent, a quality set of h beams can do it with the bolt upgrade. other then that you are looking at the 1000 billet rod area or aluminum, not much choice lol
Old Dec 16, 2008 | 06:05 PM
Yeah, I was thinking about Howard's powered steel for a bang-for-the-buck answer... but I was thinking in the 700hp range. 1000 ponies starts to limit the choices regardless of rpm.
Some high end forged rods may work (that whole tight-tolerance-forging vs billet debate again) but those aren't cheap either.
Old Dec 17, 2008 | 11:40 AM
a quality H beam like a compstar etc. with the L19 bolt upgrade can handle 1000hp thats what they rate to. thats the cheapest route to go. im going to do that for the 434 im building, 800hp+ n/a and a small single stage on top. ive seen guys run h beams to 1200hp, its all in the bolt and rpm. steel rods tend to crack more on nitrous motors, aluminum is detonation insurance. and the only choice if you plan on something 8500rpm+ with that power.
Old Dec 17, 2008 | 06:58 PM
Boostwhat's Avatar
Will not be track only as of right now. Its a 383" engine with the factory system to run it so I'm limited to around 7k rpm. Which is the reason I am going with nitrous. 2 systems and as much as I can get away with gas wise...
Old Dec 17, 2008 | 08:10 PM
ok, id just use a quality h beam with the L19 bolt then
Old Dec 20, 2008 | 05:54 AM
streetbad's Avatar
Lunati has billet 5.85 I beams. Similar to Olivers but $200.00 less. They have three different weights available.
Old Dec 22, 2008 | 11:25 PM
AutoRoc's Avatar
If you're gonna skimp...might as well be on the rods...
You could hold off on 1 kit to pay for "good" rods once.
400+ has been done effectively thru a single plate/fogger many times.
Goodluck? Sounds like a mean ride!
Old Dec 23, 2008 | 12:19 AM
rskrause's Avatar
Moderator
I don't think in terms of I-beam or H-beam. There are good (and not so good) rods of both designs. Cheapest rod I would buy is a Compstar (for a race motor or hi-performance build). They are finished and inspected properly and that is one of the biggest differences between decent and not-so-good rods. Moderate price aluminum rods are the way to go for a heavy nitrous small block on budget, IMHO. I am figuring this isn't going to be a high mileage street car? Anyway, if you want steel rods and want to spend as little as possible, and don't mind the foreign raw forgings, look at Compstar.
Rich
Old Dec 23, 2008 | 02:54 PM
AdioSS's Avatar
After seeing a handful of aluminum rod engines break when I was in Houston, I will always be leery about using them in any engine that will not see regular tear-downs. Each time the rod seemed to let go at about the same time. 100-120 WOT pulls on either a dyno or strip. I don't know how that converts to street miles, so it just isn't worth it to go with aluminum when steel is stronger and lives a LOT longer.
