Limits of stock block
Old Oct 30, 2002 | 10:24 PM
  #46
KTamez's Avatar
Originally posted by Fast Caddie
i never heard anything about the head fastener thing, care to elaborate? I guess I will be using an LT1 block for sure.
I'm not an engine builder nor an LS1 expert, but The problem lies in that the head bolt pattern is only in 4 places around the cylinder, instead of a GenI or GenII's conventional. This leads to less clamping force around the gasket which causes headgasket failures more easily. This will come into play in heavily Boosted or Sprayed Engines.
Kurtis
Old Oct 30, 2002 | 10:45 PM
  #47
89ProchargedROC's Avatar
Originally posted by KTamez
MSD Crank Trigger, MSD Sync Distributor,
Just a FYI.....those MSD dual sync distributors have had their the polarity reversed in quite a few of them including Doug Hegge's tt vette. If i ever go this route i'm using the Accel one
Old Oct 30, 2002 | 10:49 PM
  #48
KTamez's Avatar
Hmm, Thanx for the headsup........ It is still in the box brand new...... I'm sure after spending as much as I have with Summit over the years they won't mind a return.....
Just not that big of an Accell fan, though I've never had problems with them like I have with Mallory. LOL.
Hmm.......
-K
Old Oct 30, 2002 | 11:13 PM
  #49
Ya, the cool thing about the accel dual sync unit is the color LED lights for each signal
Jack @ Racetronix had some problems with the MSD units and it ended up being the same issue when Doug Hegge was tryn' to get his car tuned.
here are a few links for ya:
http://www.turbobuick.com/forums/sho...ighlight=Accel
http://www.mrgasket.com/dfiprod.html
Old Nov 1, 2002 | 01:32 PM
  #50
Kreinmc's Avatar
Ktamez, please tell me you are going to push that engine to its limits when you get to the track. Seems like no one is even trying to compete with the ls1 guys that are going all out on their motors.
Old Nov 1, 2002 | 06:07 PM
  #51
KTamez's Avatar
Keep you ear to the ground next spring/summer.
Kurtis
Old Jul 9, 2003 | 10:41 AM
  #52
Mr. Z28 73/97's Avatar
Jesse Boyer stock 4bolt
That's fine that the factory 4 bolt block held up but unless you already have one of the 4bolt blocks converting any 2 bolt block to 4 bolt mains is going to cost the same whether you get straight or splayed mains. And unless you run into a deal anyone with a 4 bolt main block is probably going to want at least $500 so you really haven't saved any money have you?
This is no flame job just stating the facts.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
MustangEater82
19
Sep 3, 2002 02:09 PM
