Lifter question, seeking help.....
http://web.camaross.com/forums/showthread.php?t=303316
Not getting any luck over in LT1 tech, thought I'd ask in the more technical area. TIA
Re: Lifter question, seeking help.....
The lifter's have about .100 working area.If they have been setting some may bled down,some do some don't,even new ones.The seat for the check ball has to be perfect not to bleed down.That means no trash,even the size of a human hair,which most people wouldn't even pay attention to in an engine,and most seats are not "that" perfect anyway.This is why you may hear the lifters clack,clack a few times when the engine is started cold.With oil pressure they should be quiet and most seats don't leak enough to be noisy with oil pressure. A lot depends on the QC of the manufacturer and what the criteria is at assembly to call a leaker a bad lifter not worthy of being shipped.
Some may be easy to push some may not push down at all-the seat thing.
I'll bet you had the same thing happen that I did (it's probably my pics you're refering to). While I never tested mine the same way you are, I would expect the one on the right:
http://www.jonaadland.com/NewPics4/No2CylCompRs.JPG
Would act the way you're describing if I had.
I pulled the valve covers tonight and took a look as best I could, and didn't see anything out of the ordinary. Strangely enough, NONE were able to be compressed.
But, last time I ran the car, I'd get a sharp snapping sound from what sounded like a couple of them.
I'll take another look once I get the car running again.
Originally Posted by Jon A
I didn't know for sure until I pulled the intake....
Looking at your picture, to me the lifter on the left looks like it's collapsed, but you mentioned the right one?? Am I missing something?
Originally Posted by LT4POWR
Did you inform Comp about your issues?
Bret
Originally Posted by SStrokerAce
Yeah he did! and they are sending him a new set. It looks like a bad heat treatment of the snap rings that hold the plunger down, it can happen.
Bret
Bret
Bret
Bret
oldschool
Feb 9, 2016 09:21 PM
donot_4get
Sep 14, 2002 08:03 AM
