Lifter Failures
Old Aug 31, 2005 | 11:58 PM
  #31
Steves396lt1
Guest
Posts: n/a
Re: Lifter Failures
Originally Posted by SStrokerAce
It's not a problem, but if a shop hasn't heard of this problem maybe they should keep up with this stuff more and more. That's why we specialize in what we do. I had this problem with a customer over a year ago, I realize I might be in the loop more than most.
There should be a sticky about these things, true but in reality we don't need a thread on both advanced tech and LT1 tech about these things.
Your not stepping on anyone here, you and I have equal rights in this forum and country which is great, it should just be one thread IMHO.
Bret
Cool. Thanks
Old Sep 1, 2005 | 05:32 PM
  #32
Denny McLain's Avatar
Re: Lifter Failures
lo, nice one Denny.
The clip design now is much different than the previous c-clip design. The older lifters are great, but the newer design is the ones that break and there IS NO WAY TO FIX THEM! As the old man said, don't try to fix them, don't try and re-engineer something (this comes from one with 30+ years of experience) that's broke, plain and simple JUST DON'T BUY THEM.
This thing is a dead horse, there really ain't much to talk about here anymore.
Bret
See if I can do a dead horse of a different color.
Again, my issue is simply loosing power after removing the Comp R's and replacing them with Morel lifters in an attempt to find a little more. Well....... we put the Comps back in and it's not the lifters.
So for what it's worth and Comp R's breaking aside...... the older Comp R's and the Morels dyno the same. The only difference is the Comp's like virtally no lash while the Morels were set at about .030.
Old Sep 1, 2005 | 05:43 PM
  #33
SStrokerAce's Avatar
Re: Lifter Failures
Did you recheck the PR length on the Morels?
I was kind of expecting that your problem wasn't the new lifters.
Bret
Old Sep 1, 2005 | 06:19 PM
  #34
Re: Lifter Failures
Bret
One of those things that you think of after you've replaced them and put the intake back on. Na, blew it and forgot. We also put a Delteg ignition on with a fresh set of plugs and it had the same effect....... no added power. We're going to try a couple of other cams and the Morels will end up back in the car but so far it's a toss up as to which one is the best if you set them up like they want to be set up.
Honestly think part of it is the poor air quality but I'm having a hard time believing you'd loose almost 40 hp from air quality.Maybe there is something after all to those red Ozone alerrts.
Even replaced the intake as evidently there is some sort of pin hole from porting that was letting oil get into the intake. Took care of the oiling problem and my home porting of the intake produced the same power as one that had an absolute max weld n port job.
After I paid for a new die grinder, fed exed paper porting kit and a new carbide grinder........ figured I saved about 10 bucks an hour doing it myself vs letting someone who really knows what they're doing do it. Hell of a deal.
Were going to bring in a car with a documented dyno sheet done on the same dyno and see how it does. Might be the air......... Might not. We'll find eventually but for sure it ain't lifters.
Maybe I should start taking bids for the older version Comp R's as they seem to be pretty good.
Old Sep 1, 2005 | 07:16 PM
  #35
97 RedSS's Avatar
Re: Lifter Failures
I still need Scott to redyno/retune my car since I installed my 42lb injectors..Maybe we can put my car on the rollers since I still have my dyno sheet from Scott's..only thing changed was the injectors...maybe the dyno is inconsistent???
My comp r's are worth $500 to me I bought mine out of a shop in Houston called GTP about 3-4yrs ago..Maybe they have some left over from way back then..
Cody
Old Sep 1, 2005 | 08:50 PM
  #36
Re: Lifter Failures
Doubt Craig has them laying around, I sure know I don't.
Bret
Old Sep 1, 2005 | 08:56 PM
  #37
Re: Lifter Failures
Cody
Dyno's are very consistent........... car are inconsistent. So, may I take your bid for $500.00? Do I hear $510.00? Haba, haba, haba.
Scotts pretty accomodating. The problem is you made changes so your dyno data won't be consistent. We need apples to apples to see if the air really makes a difference or if it's just our inability to figure out what's really going on.
Fickle fricking cars anyway.
Trust me....... I hope it's the air, but I'm not banking on it. Lifters........ nope.
Old Sep 2, 2005 | 08:13 AM
  #38
NJLT1SS's Avatar
Re: Lifter Failures
I would definitly check pushrod length if you are going from Comp R's to the Morels. The lifter body on the Morels are longer, not sure if the lifter plunger/cup is in the same height/location. I upgraded rocker arms, so I needed new pushrods anyway.
Nick
Old Sep 2, 2005 | 08:24 AM
  #39
Re: Lifter Failures
Nick
We didn't check the length but the dyno runs for both lifters are basically the same so if it's off, it not enough to effect the dyno. But your right... never take anything for granted.
Old Sep 2, 2005 | 03:57 PM
  #40
stealthblack's Avatar
Re: Lifter Failures
left field fastball going for the jackass award.............
i dont know how knew the motor is[?] have you looked at your spring pressures? i reread you posts and couldnt figure out if you lost power just upstairs or across the board.sounds like youve got some time at higher revs,older springs might be wheezing, but if its only dyno time: didnt mean to bring it up, im fairly sure its not a PS motor that needs springs every mealtime.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
