Checking compression ratio
Old Aug 31, 2005 | 07:53 PM
michaelxx31's Avatar
i know u can check a dirt bikes compression ratio with a tool, can u check a cars?
Old Aug 31, 2005 | 11:40 PM
Re: i no u can check a dirt bikes comp. w/ a tool, can u check a cars?
let me clear that up, i mean by taking the spark plug out and (or atleast this is how i think you do it on a dirtbike) and then put the tool in through the spark plug hole and cranking it up or turning it over.
Old Aug 31, 2005 | 11:48 PM
sw89lt1's Avatar
yes,
Old Sep 1, 2005 | 12:23 AM
MachinistOne's Avatar
Yes - we use them at the race track for tech inspections of suspect motors.
Old Sep 1, 2005 | 06:36 AM
glennxx1's Avatar
so you can get something at advanced and check compression ? how's it work, just put it in a spark plug whole? and would it tell me like 9:1 or does it read in PSI, and if it does how do i know what PSI = what :1 ?
Old Sep 1, 2005 | 10:17 AM
atljar's Avatar
It will read in PSI.
You really cant convert the PSI to compression because you are reading a dynamic compression of the engine, not static. Also it depends on your battery health, cranking speed, and the brand of gauge you have.
As a tool its useful to find the general health and compressing ability of the engine. You can compare cyl to cyl and see whats low, if anything. All your cyl should be within 10% of each other, and your first puff of compression should be at least half of the 4th or 5th.
Old Sep 1, 2005 | 07:23 PM
Re: Checking compression ratio
well then how do you check exactly wats your compression is (9:1 10:1 ...etc.?)
Old Sep 1, 2005 | 11:02 PM
No - there actually is a volumetric gas analyzer that can determine your compressoin ratio.
We built a motor for a super stock racer who wanted to use the pistons he had already bought, they made the static compression 9.8:1 spec for his class is 8.5:1, he was winning every race, which to his own bad luck had nothing to do with how powerfull the motor was, he is that good of a driver, but anyways, he got tested and the machine spit out 9.8:1, exactly what his build sheet says.....
Old Sep 2, 2005 | 07:02 AM
glennxx1's Avatar
work same as the other, screw into spark plug whole?
Old Sep 2, 2005 | 08:40 PM
yep
Old Sep 3, 2005 | 07:31 AM
glennxx1's Avatar
where can i pick one of these up at? and how much is it thanks for all the input by the way
pimpss96
Feb 12, 2015 01:28 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
