L88 valve springs
Old Jun 10, 2004 | 09:08 AM
breakthelawinaz's Avatar
L88 valve springs
i have the factory L88 valve springs and i got a new cam. i got the comp magnum 248@.050, .595 lift and i wonderend if i was going to run into coil spring bind? the valves are good for .680 lift with the valve seals and retainers installed but i dont know when i encounter valve spring bind. i was running a .580 lift cam with no problems so i beleive that the .595 should be fine but im not 100%
Also do you set valve lash on the comp soild cams hot or cold it does not specify. i beleive it .025 but im not sure, but i do know for sure it dosent specify hot or cold. thanks
*Eric*
Old Jun 10, 2004 | 09:57 AM
ok well i sort of answered my own question, well part of it. the cam is tro bet set hot i beleive.. and when i adjust for the first time before i start it i add .002 for cold engine iron heads iron block.
as found here...
*Eric*
Old Jun 11, 2004 | 06:44 AM
noone knows max lift for L88 springs huh?
*Eric*
Old Jun 11, 2004 | 05:36 PM
1racerdude's Avatar
springs
Just lay a head with a gasket and a couple of bolts on the block and snug it down.Install 1cyl valve train and set the lash and roll it over until each valve is all the way down.Take a set of feeler guages and see if you have .050 or more between the intake and exhaust valve spring coils. If you do you are ok with the springs. You also should check your piston valve relief's with the extra lift.
It ain't pretty when you crank it up with the valves hitting the pistons.
Old Jun 14, 2004 | 06:19 AM
Re: springs
i wouldnt think so... you make me think that you have experience in that?
thanks!
*Eric*
Old Jun 14, 2004 | 06:49 AM
1racerdude's Avatar
Valves
Yea,I have repaired customers engines that weren't pretty.
I have a small race engine shop here in LA.
Old Jun 14, 2004 | 08:21 AM
oh... thats cool! i eventually want to be doing the same thing in the next 10 years, im young enough that i still have plenty of time. i love building engines, i have done about 15 now (the first when i was 12) and when im building them i get into a zone and its just alot of fun. i would love to do it as a hobby on the side.
*Eric*
Old Jun 14, 2004 | 08:26 AM
1racerdude's Avatar
It is a lot of satisfaction.I have been doing it off and on for 45 years.Since I retired I am trying to build 5-6 engines a year.
Old Jun 14, 2004 | 11:11 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
