L-98 stroker kit, can I use it on an LT!?
Old Jul 24, 2002 | 01:01 AM
Ivan1's Avatar
Question L-98 stroker kit, can I use it on an LT!?
Hello everyone, I am seriously toying with the idea of selling my Iroc and purchasing an LT1 6spd camaro. Since I have not yet installed my stroker kit into my '88L-98(vette), would it be possible to use it on an LT1 engine? The stroker kit consists of a :eagle cast crank, rods, bearings, KB hyperkeunetic(mispelled)pistons, LT4 hot cam, compcams springs(#986-16), 1.6 pro-magnum roller rockers, fluiddamper balancer,
any info would be great!!!
1987 Iroc,black,t-tops mods:383 L98(LT4 hotcam) TPI engine from '88 vette with factory aluminum heads,B&M 700r4 shift kit,3"flowmaster exhaust with headers,9bolt 3:27 posi-disc,aluminum driveshaft,performance chip,eibach springs,K&N filters,removed MAF screen,gutted airboxes.Also own a 1996 Grand Am GT 2-door(Mods...new wiper blades and air freshener)
Old Jul 24, 2002 | 11:39 AM
Lowend's Avatar
Post
The Crank/Rods/Pistons should fit, its the same 1-piece rear main seal on the block. The balancer is not interchangable (I can't remember what is different). I belive there is a pin in the end of the LT4 cam that needs to be relocated depending on is use in an LT1 or traditional SBC.
Old Jul 26, 2002 | 01:20 PM
Dr.Mudge's Avatar
Post
The 95+ FBodies use a longer dowel pin, which you can buy fairly inexpensinvely. But the hole in the end of the cam is a different size in the early vs late LT1 also, and would have to be precision drilled or just buy a new cam.
If you go 93-94 FBod though the short dowel should work, as far as the hole for the Optispark though I dont know if the L98 Hotcam would be the same or what.
You can get the cam itself for about $169
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
