Intake port roof slanted?
Old Jul 25, 2002 | 08:42 PM
SABLT194's Avatar
Post Intake port roof slanted?
What the theory on the slanted intake port roof on the LT1 heads? Its seems that since most of the flow favors the port roof, that removing ths slant would provide more flow up top. I've also heard that removing the slant is bad practice on these heads. Opinions please.
94 Formula M6 4.10 Strange 12 bolt Spohn Subs,LCA,LCA Brackets, & PHR,Moroso Cold Air, B&M Ripper w/ T handle/w switch , Hurst Line Loc,ET Streets, FLP's with B&B Triflow's, Taylor Wires
Street Twin, Spool
CC306, R lifters, Pro Mag 1.6's
Cloyes Double
Protune by me (Protune?)
3710# Pig Fat Race Weight
335 RWHP best 60' - 1.76
Best 1/8 - 8.05 @ 86.5
No 1/4 times yet
Old Jul 25, 2002 | 08:47 PM
Soma07's Avatar
Post
I always figured it was there to help promote swirl. Although all of the aftermarket/ported head i've seen do not have the same slant to the roof.
Jason
93 TA, M6
Old Jul 26, 2002 | 01:16 PM
Dr.Mudge's Avatar
Post
For one thing, look at the intake, why would you go from a slant to an abrupt flat roof in the head? Let it do that in the bowl.
Old Jul 29, 2002 | 12:34 AM
Soma07's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Dr.Mudge:
For one thing, look at the intake, why would you go from a slant to an abrupt flat roof in the head? Let it do that in the bowl.</font>
Long time no see Doc
Is the port roof on the intake manifold really slanted? I thought it was flat but I'll admit I didnt pay much attention to it.
Anyways does anyone have anything else to add on this subject? I would really like to know more about why its done that way.
Thanks!
Jason
93 TA, M6
Old Jul 29, 2002 | 02:51 PM
triumph's Avatar
Post
Removing the slanted roof will add more volume but you will have less preasure.Most of your A/F mixture will flow in the lower half of the port. If you remove the roof you disrupt the flow. If you have a cam over .650 lift you may gian from removing the roof. Steven
Old Jul 31, 2002 | 11:43 PM
arnie's Avatar
Post
Are we talking port roof or port wall. The oem lt1 and lt4 heads/intake I've delt with have a parallel/flat port roof, but one wall is slanted in on the intake of each.
I'll be back
Old Aug 1, 2002 | 10:30 PM
nuke61's Avatar
Post
Here's a picture:
http://nuke61.homestead.com/files/He.../RoofSlant.JPG
Hear LT1 cam WAVs, DIY head porting: members.***.net/gmarengo
'95, !CAGS, CAI, ForceII, Hooker Shorties, 14.2@103
Old Aug 2, 2002 | 08:20 AM
Post
Or... A=LT1, B=LT4
http://home.tir.com/~steveher/intake.jpg
Old Aug 4, 2002 | 04:17 AM
arnie's Avatar
Post
Fred, ?
Anyway, the port roof on both LT1s & LT4s I've come in contact with, are true/parallel with head mtg surface. This allowing 1/64-1/32 for casting irregularity. It is the short side port wall slant that is very prominant on the LT1. But the corresponding intake/plenum wall is dead square, which makes for a restriction into the head. The wall slant to me looks to be by design.
The LT4 head short side wall appears to be square by design, allowing for slight casting irregularity. However, the corresponding intake/plenum port wall has a definite/deliberate slant designed into the wall. This however, will not pose a restriction/blockage, being smaller than head port. Ironically, the deliberate LT4 plenum slant mimicks the deliberate LT1 head port!
I trust I didn't loose anyone explaining.
My reasoning on the LT4 plenum port slant is for reversion for the LT4 cam specs. Agree? The LT1 head port slant defys logic to me. I'm listening.
I'll be back
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
mightymouse383
May 21, 2015 05:31 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
