Intake CC...volocity vs. volume?
Old Apr 11, 2006 | 08:47 PM
12SCNDZ's Avatar
I originally had my heads ported 3 years ago. They flow 271 CFM @ .550". My head ported firmly believed that intake CC volocity is more beneficial than overall volume. Because of this, my heads only have 175 CC chambers. The valves are undercut Manley 2.00" / 1.56".
With these heads, cc305, and a stock 95,000 mile bottom end, I went 12.0 @ 112 MPH with a 3448# full weight '93 Z.
The new combination is a 6" rod, 847 cammed, 12:1 355. My goals is low 11's on the motor (11.2-11.3). I'm trying to figure if these heads will work for the new combination.
Any thoughts about volocity vs. volume?
Frank
Old Apr 11, 2006 | 11:28 PM
Kraest's Avatar
Retired
Re: Intake CC...volocity vs. volume?
Airspeed and Velocity is crucial, but a 175cc head is going to be restrictive with a 350ci LT1 and your MPH shows it. Even though you ET well, you're lacking in the horsepower department. I also think those 271cfm @ .550 numbers were inflated.
Mike
Old Apr 12, 2006 | 03:49 AM
jimbob65's Avatar
Yeah, just alittle......
Pinch rod area is very important for correct peak rpm hp vs. cubic inches. With a good area (for your cubes) and proper porting, your cc's come out where they come out!!!!!!!!!!!!! For an LT1 head your looking at 195cc's as a minimum port, and more likely 205-210cc's Also a stock port LT1 cc's, is around 170-175ish by the way.
Old Apr 12, 2006 | 03:25 PM
LT1 1980 malibu's Avatar
very true...the cc sounds kinda small...Did he actualy recontour the ports or just did a flap wheel and cross buff clean up?Its been about a year since ive hogged out a set of sbc heads but i do know they need more than a fancy pretty polish job...
Velocity is great when you can keep it up but you need to increase port volume to make power in the higher RPMs..Larger ports dont hurt the low end as much as people tend to think...Besides you can always loose a little down low since the car will hook better.
My last set of LT1 heads specced out to 198cc and flowed 285cfm at sea level on the intake 188 on the exhaust.That was with stock 1.94 intake valves and 1.625 exhaust valves.
Old Apr 12, 2006 | 06:27 PM
96capricemgr's Avatar
Try telling that Advanced Induction's customers their top LT1 oem casting head is 190cc and they make power, Lloyd goes much bigger in port volume and his customers make power too. Chalk it up to more than one way to skin a cat ?
Old Apr 12, 2006 | 07:23 PM
SStrokerAce's Avatar
All depends on where the velocity is in the port...... if you can have the velocity thru the pinch and over the short side not get crazy then you can shrink the port. Lloyd also looks at some other things inside the port and makes the heads bigger so they work well in those areas.
Bret
Old Apr 13, 2006 | 04:10 AM
jimbob65's Avatar
OK AI head owners...your ports are tooo small.....
Actually, 190-195 sounds about right for their heads, I was off by 5cc's on my low estimation .....I'v skined that cat 100 times, can't believe it still needs more.....
Your right though, even those ports are one heck of alot bigger than 175cc's. I just can't see how with some standard porting measurements needed to make good airflow. How you could get that small of port, for some upper rpm breathing....(take that with a grain of salt, though as I'm certainly not a head porting guru) Maybe Lloyd or AI could pop on here and give the guy some help....
Old Apr 13, 2006 | 05:52 AM
LameRandomName's Avatar
If I'm not mistaken, too much velocity is bad too. Too much velocity makes the flow "behave" badly.
Old Apr 13, 2006 | 07:41 AM
contactpatch's Avatar
velocity is important, for carburetors.
otherwise, the important thing is how much air is retained
when the intake valve closes.
if you want velocity, block off 99 percent
of the intake port on the cylinder head
Old Apr 13, 2006 | 10:38 AM
When is the world going to realize that carbs and fuel injection motors don't need different things 99% of the time?
Old Apr 13, 2006 | 02:22 PM
Gee, I was under the impression that carbs needed a pressure drop.
Old Apr 17, 2006 | 08:24 AM
ok, the carb itself needs venturi-pressure-drop to function,
carb setups also need velocity to keep fuel
droplets from falling out of suspension.
other than that, the real issue is how much fuel-air
mixture is retained in the cylinder
Old Apr 17, 2006 | 08:46 AM
I dunno...
I've seen some guys run pretty big carbs and have them do just fine.
Tuning a carb is more than just changing jets.
carl.froehlich
Mar 13, 2015 12:38 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
