If Magnafluxing doesn't work on Al, how do I check for cracks?
I'm picking up a car that is supposed to have "cracked heads". It overheated and ran hot for a while. The heads are Al and I'm not sure if it's blown head gaskets and warped heads OR if they really are cracked. How can I check for cracks?
Now, I know the cracks should be on the intake side of the head where the head bolts go through, but will I see them?
I hate to spend $150 for a shop to tell me they're cracked when I could get another set for $200. Who wants to spend time and money on heads to find out they were a mistake? So, how can I avoid the waste?
You can't magnatize an aluminum head so how do you check it for cracks? A dye?
Still learning,
Ben T.
Still learning,
Ben T.
Re: If Magnafluxing doesn't work on Al, how do I check for cracks?
Still learning,
Ben T.
Still learning,
Ben T.
On my heads, they shaved a little bit from them to make sure they were true, then they vaccum tested them on some kind of fixture. I'm not sure of the exact process, but those heads had gotten darned hot and are perfectly fine.
I'm also not sure that aluminum heads can "crack" I think they will just warp... But, my .02 cents is only worth about.00005 cents on that
-Shannon
-Shannon
danielbmx
Aug 27, 2002 11:11 PM
