I don't under stand RODS 5.7",5.85",6" and pistons for C ratio
Old Dec 18, 2004 | 11:22 PM
  #16
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Re: I don't under stand RODS 5.7",5.85",6" and pistons for C ratio
best thing to do is talk to your builder? that is what i do when contemplating changes to the combo
Old Dec 20, 2004 | 03:10 PM
  #17
SStrokerAce's Avatar
Originally Posted by ws6transam
.045 inches is supposedly tight. I'm running .046 inches on my new, yet untested engine. As long as crank and rod bearings stay together, and the piston doesn't rock too much from a worn cylinder wall, it should, in theory, be fine. If, however, you destroy a bearing and the rod gets to knocking, the clearance rapidly goes away as the piston/rod wont accurately track the crankshaft. The result is the potential that the piston could make contact with the cylinder head deck surface, causing further destruction. As least, that is my own understanding and is NOT based on any direct experience. I'm currently running a 0.044 inch clearance on my old Feeble305 and it hasn't spit anything onto the pavement yet, even after eating the lobes off a cam two summers ago.
Some of us think that .030 is tight. .040 is usually a good number to shoot for but .035 is pretty safe most times. It all depends on the piston alloy, piston to wall clearance RPM limits etc...
Bret
Old Dec 20, 2004 | 03:22 PM
  #18
1racerdude's Avatar
A long time engine builder I know says "they run their best when the piston barely touches the head" but I would leave a little clearance because most people won't measure close enough to achieve that "barely" figure.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
pimpss96
Feb 12, 2015 01:28 PM
