how many hp does p/s eat?
how much power does p/s eat?
Does anyone have any e/t drops or chassis/ engine dynos # for power steering vs manual. I am considering not hooking it up on my s10 to save some hp and loose weight, Im going for the power to weight in a big way
. A bit un advanced tech; How does p/s work does it free wheel unless if you are stering or is it always pumping?
Eric Myers
. A bit un advanced tech; How does p/s work does it free wheel unless if you are stering or is it always pumping? Eric Myers
should probably be moved out of advanced tech, but here's an answer.
power loss -- no dyno #s, but little. maybe 3-5hp when turning.
it pumps all the time, but uses more power when turning than when it's not.
It does make a decent weight savings (pump, lines, fluid), but if you are going manual, get a manual rack. the power rack without power assist is harder to turn than a manual rack.
cmsmith
Apr 10, 2015 10:03 AM
