How to fit LS1 motor mounts in an S-10
Old Jan 24, 2003 | 09:37 PM
supermo26's Avatar
I am planning a conversion for an 87 2wd S-10 Blazer. I would like to install an LS1 that came out of a wrecked 98 Firebird.
I am still working the motor mount conversion and need to know if the mounts are the sames as a regular V-8? Does an one know how I can adapt a 2.8L motor mounts to mount an LS1? More questions to follow. James supermo26@hotmail.com
Old Jan 24, 2003 | 11:02 PM
Fast Caddie's Avatar
What do you plan to do this thing? Make it a super-typhoon or something? If you just want a V8 in your blazer, then go for a 350 vortec or something out of the GM trucks. Much easier swap as per the truck boards I use to frequent.
I have no clue as to the LS1 dimensions though, sorry
Old Jan 25, 2003 | 08:10 AM
OldSStroker's Avatar
You might start here:
http://www.jagsthatrun.com/
As far as I know they haven't published anything on LS1/S-10 conversion yet, but if anyone is working on it, JTR probably is.
Just doing a SBC conversion is a bunch of work; the LS1 will be challenging.
Old Jan 25, 2003 | 09:02 PM
slammed98gmc's Avatar
www.leeshightechtrucks.com is a much better and freindler place to shop for knowledge. Jtr will pressure you into buying their books instead of anwsering questions.
Old Jan 26, 2003 | 09:00 AM
Good link. Here's a quote from them:
The LS1 swap is the most difficult so far of the small block S-10 conversions. To list all of the clearance problems, and things to look for would take too long. Just plan on taking a while to do it. We have found that a Camaro LS1 with Corvette accessories seems to be the best fit. ANY engine, whether a V-8 or 4 cyl can be installed in an S-10, we just prefer to stick with what we believe works well and is dependable. Often times this means designing our own parts such as headers and radiator to use. This is how we are able to build reliable trucks on a regular basis. Our prices are not often for the backyard mechanic. This is because our parts are custom built for our needs, and used in our regularly performed in-house conversions.
Your truck, your engine and your transmission and they'll do the conversion for $9500.
Old Jan 26, 2003 | 11:41 AM
supermo26's Avatar
Both of the places mentioned above are more worried about getting your truck to do the swap for you rather than giving you info and selling you parts. I have spent a lot of time on the web and the info out there for the LS1 in a S-10 is very limited. I have seen a few LT1 installs and a few chop job installs but that is not what Im looking for.
I want to find some motor mounts or adapters that will allow me to adjust the position of the block to help clear steering and manifolds. I have seen JTR's and Stealt"s but they are not very quick to respond. In the mean time, I'll keep researching the web and checking the Boards. THANKS James
Old Jan 26, 2003 | 12:27 PM
I can speak from experience that Lee is a very helpful guy that will talk to you on the phone and through emails.I have their wiring harness on my truck and will soon have there long tube headers.Im happy with the products so far.They sell the parts ,just call them up
Old Jan 26, 2003 | 12:28 PM
And they are in florida too...........
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
