How do they make piston rings have that "spring" to them?
Old Jan 28, 2006 | 07:37 PM
Damon's Avatar
I was thinking about how rings are manufactured and it all seems fairly straight forward, but how to they make the metal have that spring to it that holds pressure against the cylinder bore? I'm sure it's some sort of intentionally-induced stress in the metal before it's ever machined and cut open for the ring gap but how dey do dat?
Old Jan 28, 2006 | 07:55 PM
Johnny Ray's Avatar
Freebird
Re: How do they make piston rings have that "spring" to them?
The radius of the rings are larger than the bore that they are designed for.
That's why you need a ring compressor in most cases to install them.
Old Jan 29, 2006 | 11:23 AM
OldSStroker's Avatar
It's not as straight forward as you might think. Just grinding the outside diameter is a challenge. How would you do that in a couple of seconds per ring?
Yes, a lot of what makes the ring work is the stress in the metal, and how that is managed. Some compression rings twist so that the bottom edge contacts the bore harder than the top. If you've ever installed a ring upside down you might figure out how "dey do dat."
Old Feb 5, 2006 | 08:38 PM
NastyTA's Avatar
It's not the tension that seals the ring in the bore. It is the combustion gasses getting behind the ring in the groove that pushes it agains the bore.
Old Feb 5, 2006 | 11:18 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
so I guess during the intake stroke the rings dont seal?
Old Feb 6, 2006 | 08:41 PM
NastyTA's Avatar
The tension does. But it's not as important because the ring doesn't have the combustoin pressure fighting it.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
