how do flowbenches work?
Old Sep 20, 2005 | 07:40 PM
'68LT1camaro's Avatar
Anyone care to explain in detail how a flowbench works?
Old Sep 20, 2005 | 08:19 PM
Stephen 87 IROC's Avatar
Re: how do flowbenches work?
http://www.ag.auburn.edu/users/gparm...es/flowbench2/
Old Sep 20, 2005 | 10:36 PM
Zero_to_69's Avatar
I can see it now...this will be every grade 9's experiment for the Science Fair this year!
Old Sep 21, 2005 | 01:26 AM
1racerdude's Avatar
Ya blow air in and measure what comes out.
Old Sep 21, 2005 | 06:58 AM
OldSStroker's Avatar
They suck...or blow, like a lot of other things.
Google is your friend. Here's something cribbed from Superflow's web site.
(it was the first result on a Gooogle search for "flowbench works")
"How does a SuperFlow flowbench work?
A SuperFlow Flowbench measures the airflow at a constant test pressure. The pressure drop is measured across the test piece (a cylinder head for example). Using the ratio of this pressure drop to the pressure across a known (calibrated) orifice, it is possible to determine volumetric flow.
SuperFlow recommends that you pick a standard test pressure (in inches of water). This makes all your results directly comparable. This is similar to applying the same voltage across a resistor to measure the current going through it.
SuperFlow also recommends that you take readings throughout the range of valve lifts. Not just at the maximum lift of the valve. The most important part of the flow frequently occurs just as the valve is closing. The last bit of air on the intake makes the difference whether the engine obtains 90% volumetric efficiency or 100% or 110%.
To begin a typical test, you set a cylinder head on top of a cylinder adapter, with a dial indicator on the valve. A threaded bolt-type device is used to push the valve open. Use lighter valve springs to make your test-valve-actuation easier. Don't fight the big heavy spring. The lighter spring must be stiff enough to keep the valve from being sucked open during the test. Watch the exhaust valve when testing the intake. On the exhaust, the air is blowing in the opposite direction, so the valve won’t be sucked open.
SuperFlow recommends that you always use a radiused inlet guide when testing a cylinder head by itself. A radiused inlet guide has a rounded shape to guide the air into the test piece. A sharp edge at the port entrance will cause the air to flow in toward the center of the port rather than following the port walls. The edge acts like it is choking the airflow. The flow difference can be as much as 30% due to the sharp edge effect. The radiused inlet guide directs the air straight into the port with a small loss, just as it would be if an intake manifold was connected. When an operator tests his head without a radiused inlet guide or an intake manifold, his results will be very different than your results. So it is critical to use a radiused inlet guide. The radius should be about half the width of the port. For a 2" wide port, use a 1" radius radiused inlet guide as the minimum dimension. The same radiused guide should of course be used for all comparative tests.
Air is moved through the cylinder head by an air pump or blower. This is similar to a vacuum cleaner motor. Most flowbenches use more than one blower. The blower sucks the air in and blows it out at a higher pressure on the other side. These blowers will draw, depending on the model of flowbench, between 70" and 110" of water vacuum. Inches-of-water is a pressure measurement that is based on the height of a column of water that the pressure will support. For general reference, one atmosphere is 403" (10.3 m) of water. One psi (6.9 kPa) is 27" (68.6 cm) of water, approximately. With a typical SF-600 flowbench, a pressure of 25" (63.5 cm) of water is used, which is slightly less than one psi.
As air is drawn in through the port, the flowbench must measure the pressure drop. The test pressure meter measures this pressure drop. It does it by simply comparing the test pressure just below the cylinder to the atmospheric pressure. As the flowbench creates suction below the cylinder, it pulls on the fluid column and the amount of pull determines the height, and that indicates the test pressure. It works just like a pressure gauge. The column of water requires very little calibration, and it remains very stable over many years. Some flowbenches have been in operation for more than 20 years without service. This column of water is called a manometer.
A second manometer is used to measure the actual flow. The flow in the flowbench is measured by comparing the pressure loss across an orifice. This is a sharp edged orifice. It’s just a hole in a thin plate. The pressure drop across the orifice, as the air flows through it, is measured by measuring the pressure above the orifice and below it. The pressure difference is measured on a manometer again. This manometer has a slanted tube to read 0 to 6" (0 to 15 cm) or 0 to 13" (0 to 33 cm) of water on the SF-600 bench. By inclining the fluid column, the scale is extended. So if the actual height is 13" of water, by slanting the tube on its side, the scale is effectively 25" long. The slanted manometer is easier to read accurately at low pressures.
It is important to maintain the same test pressure as the valve is opened. Open the valve from 10% of its diameter to 20% of the diameter, and the flow might go from 100 to 200 cfm. The test pressure will drop if you don’t adjust anything else. Before you were measuring the test pressure at 10", now it might be 8". You'll need to adjust the flow level back to the test pressure. This is what the Flow Control **** does. It has a valve very much like the valve in the engine, with a thread on the end. The Flow Control opens and closes an orifice. Adjust the test pressure back to the standard test pressure for every valve lift. Then read the flow meter.
The flow meter displays percentage flow of the orifice maximum capacity. If an orifice has a maximum capacity of 100 cfm and the reading is 90%, the flow is 90 cfm. That principle is used in all the flowbenches.
The flowbench must be accurate through a wide range of flows. At very low flows, down at the low end of the flow meter, you can’t read it very accurately. It’s a small change compared to the total flow, so you lose sensitivity in flow measurement. To offset this, you can use multiple orifices. Some of our benches use as many as ten ranges. This provides good sensitivity at very low flows and high flows. On a SF-600 flowbench, there are six ranges from 25 cfm to 600 cfm. When running a test, select a smaller range for low valve lifts and a higher range for high valve lifts. Make sure the maximum orifice range selected is slightly greater than the flow of the valve for best sensitivity. The FlowCom will do this electronically, and it has a much wider range. Consequently, you can use a single range with FlowCom for all the measurements.
You can save time if the flowbench is able to flow air in both directions, because it saves moving the head around on the flowbench. To reverse flow, on some models, a system reverses the flow direction. There is a **** on the front of the bench, or levers, that change the flow to the intake or exhaust direction. One lever flips the connections to the manometers so that it sucks on the other end on each manometer. The other lever changes the control plate in the flowbench to reverse the flow direction. Then the air blows backwards through the cylinder head. There is another control valve for either intake or exhaust test pressure control. To reverse the flow, close the intake **** and open the exhaust **** to let the exhaust flow occur and flip the manometer and flow direction levers. Then the air flows the other direction.
For an air flow motor of this type, the efficiency is only 50% to 60%. The rest of the energy becomes heat transferred to the air. As a result, the air gets warmer in the exhaust direction as it goes through the bench. The temperature does not affect the flow reading because the flowbench measures the ratio of the pressure difference across the orifice, to the pressure across the valve. Both the orifice and the head see air at the same temperature, density, and humidity. A flowbench of this design provides results, which are independent of the atmospheric conditions. In fact, if you put a cylinder head on the flowbench, and run it at a barometric pressure of 24" of mercury, and run it later at 29" mercury, with the same cylinder head, you will get exactly the same flow numbers. You don’t have to correct for temperature or correct for pressure.
The exception to this is on the SF-60 and the SF-110/120 flowbenches. They both have the blower actually located in-between the inlet orifice and the outlet orifice, because that makes for a less expensive design. A temperature correction, which ranges from 0 to 4%, is necessary. There are thermometers built into these flowbenches for this correction."
Enough detail?
Old Sep 21, 2005 | 08:41 PM
A head can be flowed using any column of water measurement. It can easily be converted to 28" of water measurements. The 28" number is a standard and represents 1 PSI of pressure.
Lets say a head is flowed at 200 CFM at 25". If converted to 28", the CFM will also increase to something like 220 (not exact but used as an example)
So comparing flow numbers means you need to also know at what they were calibrated at.
Old Sep 21, 2005 | 08:50 PM
Thanks guys. I think I'm going to try and build something like the one in the link. I've always wanted one. I had heard that you could build them, but thought it was a bad idea. Then I found out that one of the best head porting guys here in town (Pete Kotzur of Kotzur Racing Heads) use to have a homemade bench that he used for a long time. I guess a homemade one can't be that bad. I'll give it a try.
Raymond
Old Sep 21, 2005 | 08:52 PM
Zero_to_69's Avatar
I guess homemade is never bad if you can calibrate the bench to meet
industry standards.
From a quick glance, the bulk of the cost will be sunk into the manometer?
Old Sep 22, 2005 | 07:23 AM
More than likely the several vacuum motors needed to get 28 in of H2O depression will be the major cost. Remember this was written 12 years ago, and the $500 was a little(?) optimistic even then.
Check Audi Technology website:
http://www.audietech.com/
Under "Flow Quick" click "Air Supply Plans" and "Flow Quick FAQ"
Old Sep 22, 2005 | 10:34 AM
aggiez28's Avatar
industry standards.
you dont need to meet industry standards really. you just cant really compare your results with other benches.
but you can compare before and after #s. you can see how things are improving. you may not actually know real #s though.
brook
Old Sep 22, 2005 | 11:03 AM
Zero_to_69's Avatar
Yes, that is true.
It would be a great tool to gauge improvements as a relative quantity.
However, if a consumer wanted to compare a set of heads, they might feel
more comfortable knowing the parameters were a 'standard set'.
I guess the next question would be, is there really a standard procedure?
I've been reading that repeating flow tests across different benches rarely
yields similar data.
Any truth to this?
Old Sep 22, 2005 | 12:24 PM
Your absolutely right. The motors will eat up that $500 right off the bat. The absolute max I can see my self needing would be just over 400cfm for big block heads. If I wanted to be able to measure up to 500cfm, it would cost me right around $500 in vacuum motors.
Old Sep 22, 2005 | 07:34 PM
I picked up a great little digital manometer off Ebay for $30. I use it for checking crankcase pressure (blowby) in diesel engines. It's so much easier to set up than a slack tube manometer.
Old Sep 24, 2005 | 10:47 AM
robertg's Avatar
hey stephen, who makes that digital manometer? for the price, i'd be interested in one.
Old Sep 24, 2005 | 10:42 PM
I have the TPI 615 which lists for around $180 so I got a great deal. The TPI 625 would be what you want for a flow bench since it has 2 inputs. One for the incoming air and the other for the outgoing air. That way you wouldn't need 2 manometers.
http://www.reliabilitydirect.com/for...15-620-625.htm
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
Roadie
Feb 16, 2015 10:34 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
