How bad do Copper Head Gaskets leak on the street for a daily driver
Very fine gasket seal. So, I should tell the place that does my heads to be sure the surface is smooth.
I read on another website where he put 1200 grit compound paste on the head and moved it in a figure-8 over a flat steel surface. He claimed the end result was perfectly straight and near mirror finish. Is that overkill?
I doubt you will even feel the difference.
You don't really see it at the store. I bought it on line at Sheid Diesel http://www.scheiddiesel.com/Valco.htm- scroll to the bottom of the page. I used the aerosol spray. They also sell the chemical to get it off cause nothing else dissolves it. Other guys have used Coppercoat, saying that has Hylomar in it, but I went with this. I do use Coppercoat for a lot of other stuff, and it works very well, but I have heard mixed reactions from using it on head gaskets.
