How about good pics on the net of a Nextel Cup Block...
It's amazing what you find on ebay... http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Good pics of how a block should be done....
Thought you guys would enjoy that.
Bret
Bret
Re: How about good pics on the net of a Nextel Cup Block...
Originally Posted by TheNovaMan
Are all the non-machined surfaces sanded? Is that to remove potential stress risers or to be sure all the casting sand is gone?
I'm amazed this is all you guys are picking out.....
Anyone notice that the lifter bores look more like a BBC block?
How about the fact that it's a 2.300" main block?
What the intials on the rear main cap are?
Bret
Jeff,
I've always used Devcon but there are a number of different brands that'd likely be suitable.
Neat block... she's a smoothed, bushed, cam-tunneled, roller bearinged, epoxied, screened thing of beauty. Wish they had some better pics though.
Bret, what's your bid?
-Mindgame
-Mindgame
Is it me, or does that camshaft opening look larger than a standard SB?
I also see needle bearings in that photo.
The lifter bores are also offset with clearancing for the intake push rods.
Thanks for the pics!
EDIT: Just read the info. SB2.2! Are all of my above findings standard for SB2.2?
Probably a 55mm Cam in that so yeah it's big...
MG, no bid.... what am I going to do with a 4.178? bore and a 2.300" main? Hone it .003" and get a billet or grind down a SBC crank?
I just like seeing this, we can look at SB2.2 heads all day long but the boring ole blocks are actually pretty cool to see. I've looked at the Toyota and Mopar versions as well too bad there are not pics of them on the net, but then again the Chevy versions really relate to us more, you could turn a LT1 block into that if you wanted to, or use a lot of things from that on one.
Bret
Bret
You can do it!
Bret
Bret
The stuff on Kaase's builds was just amazing.
-Mindgame
Deck height is standard at 9 inches. Can't they use different deck heights like in the NHRA?
So the 2.3" mains (instead of 2.45") are to reduce bearing speed, right?
I also noticed the lifter bores are 0.875" (Ford) instead of the standard 0.842" Chevy lifters. Why don't they use the 0.904" Mopar lifters? I know they're limited to flat-tappets, so it seems like they'd want the fattest lifter they could get.
The 2.3" mains are for reduced bearing speed, but if you look at it a 3.25-3.31 stroke with a 1.85" rod journal already has a ton of journal overlap so why not go smaller it doesn't hurt the strength of the crank.
The .875" lifter bores are mandatied by the rules, can't go bigger. I'm sure they would do a 1.000" fliter if they could but rules are rules.... the .875" was put in place back in the days before we had Mopar in Nextel Cup.
Bret
Originally Posted by Mindgame
[in my best Bronx accent]
You can do it!
You can do it!
Oh I agree Bret. That's one thing I really liked about the EM challenge was getting to see the block work and tricks people were using. Wish they could have covered stuff from the other builders (non-top-3) cause I'm sure there were lots of great ideas.
-Mindgame
-Mindgame
Bret
From: I reached back like a pimp and smacked that LS1....
That is beautiful. Crazy amount of work there.
So that 'cam tunneling' is to reduce windage from oil drainback?
If so, why would they not just cast the block like that? (Those pieces of metal look a bit risky to me)
