HELP! Need valve guide size for LT1
Old Apr 23, 2003 | 03:04 PM
nosfed's Avatar
Red face HELP! Need valve guide size for LT1
Allright if I can get a day or so on the board I'll delete this post, but this is the only place I'm likely to get an answer on this.
I dropped off a set of heads at a shop today, and the builder called me saying he can't find the guides I need. It's an aluminum headed LT1, and the problem is that the OD is bigger than a regular SBC. I know a place that has the right guides, I just need to know what to order.
THANKS!
Old Apr 23, 2003 | 03:28 PM
96 Comp T/A's Avatar
The guide diameter according to the specs from the place I got mine from are .5575 " The guides you need are available from a place called in SI Valves in
Bronze Mangenese. Part # is VG 9436/ and If memory serves me correctly they are like $2.50 a piece (you will need 16) These guides are a little long but I just trim them up when cutting the valve seal O.D.
HTH, Jason
Old Apr 23, 2003 | 04:24 PM
Joe Racer's Avatar
SBI/ J-Loy part # 140-8180 is a stock replacement if you don't want to mess with bronze.
Old Apr 23, 2003 | 05:45 PM
nosfed's Avatar
Thanks guys! I just ordered the manganes bronze ones from SI valves. I'll delete this tomorrow
Old Apr 23, 2003 | 11:56 PM
Soma07's Avatar
But why? I would leave it here so that anyone else looking for the same info in the future could find it via a search.
Old Apr 24, 2003 | 01:00 PM
nosfed's Avatar
My impression is that my topic is a bit too simple for this forum. I'll leave it up, and let the mods decide whether to delete it or not Ehhh.. I did search all the forums without finding this info.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
Jul 4, 2005 05:00 PM
