Help computing DCR
Help computing DCR
http://kb-silvolite.com/calc.php?action=comp
I'm planning on a new heads/cam/intake setup and want to run 11:1 static compression. I've heard as long as the dynamic CR stays in the 9.0-9.2 range you will be able to run pump gas. The calculator I linked above requires you to know IVC @ .050. My cam card gives valve timing events @ .006. What do I do?
You can use this calculator which uses the @.006 durations to find your DCR. For pump gas you want it between 8.0-9.0 with most running close to 8.5 or less.
http://www.empirenet.com/pkelley2/DynamicCR.html
You have to download it at the bottom of the page and install it.
14
Aug 11, 2015 12:03 PM
