helium in tires?
Old May 29, 2004 | 12:39 AM
got_hp?'s Avatar
helium in tires?
an old school figure8 track racer i met told me they used to fill their tires with helium instead of air because it was lighter and therefore made less weight/rotatiing mass?
was this guy off his rocker, or is that for real?
Old May 29, 2004 | 07:10 AM
Brady's Avatar
Helium is expensive and it's a very small molecule, it will leak out where air won't. You could spend money better elsewhere.
Old May 29, 2004 | 08:57 AM
got_hp?'s Avatar
i wasnt considering actually doing it.........i was just curious if it actually was a valid theory.
Old May 29, 2004 | 09:25 AM
TonyJ's Avatar
Well, the good news is that if your car broke down, you could carry it home on a string.
Old May 29, 2004 | 09:49 AM
Mindgame's Avatar
Air is about 80% nitrogen and some 20% oxygen with helium and other stuff making up a very small percentage.
Now, if you look at the atomic weights of helium vs nitrogen alone, you'll see that your friend is right. By my numbers, 1 liter of nitrogen (I'm simplifying without adding in the oxygen) weighs ~1.25 grams vs helium at ~.179 grams per liter. That's a factor of ~7.
I'd guess that there is a slight weight savings but probably not anything substantial. I know they use to use nitrogen in aircraft tires for the same reason.... weight reduction.
-Mindgame
Old May 29, 2004 | 12:38 PM
oil pan 4's Avatar
There is a 4X4 truck guy in my shop that use to do it to his trucks so they could go through mud better and hydroplane over water so he said.
And I have also herd that dragsters do it to, they say it is lighter, it doesn't expand as much as air.
If you wanted you could just use Argon, it is cheaper and all most as light with the other same trates.
Old May 29, 2004 | 02:57 PM
OldSStroker's Avatar
-Mindgame
Dry nitrogen doesn't freeze at -70F, the temp at jet cruising altitudes. Air generally has water vapor in it which freezes at high altitude and boils if the tires get hot during a hard stop. Neither situation is confidence-inspiring to the pilot. Water vapor in air screws with pressure on race tires which regularly get the rubber above 212F. N2 is used here, too.
Weight isn't really the reason Nitrogen is used, IMO. I agree that helium leaks out easily because the molecules are so tiny.
FWIW, a jet fighter may have 200 psi main gear tire pressure and if it's carrier based, nearly 300 psi. A 30,000 lb fighter crashes onto a carrier deck at nearly 150 mph on two 14 inch tires not much larger than a typical car tire...but one hellofa lot stronger.
Thought experiment: When you accelerate hard, does the air "slosh" around in the tires and throw them out of balance?
Old May 29, 2004 | 05:46 PM
Stephen 87 IROC's Avatar
If you're travelling at the speed of light following someone else who's also going at the speed of light and you flash your headlights to pass will they see them? Will you see the red and blue police lights in your mirror when they stop you from speeding?
Old May 29, 2004 | 06:26 PM
Valkyn71's Avatar
My highschool math teacher spent an afternoon working out that problem and came up with no.
Old May 30, 2004 | 06:20 AM
Socrates's Avatar
If you’re traveling at the speed of light and the guy behind you also traveling at the speed of light flashed you. You will indeed see him flashing you, however that does not mean that the photons of that light beam are traveling at twice the speed of light because they are actually only traveling at the same speed as both cars. I know this seems impossible and bizzare but that is what actually happens. The speed of light is the only true physical universal constant.
This was explained to me by someone with a PhD in physics, but I forgot the full explanation.
Old May 30, 2004 | 09:34 AM
Nope, they won't see your flash.
If you could see the cop lights, would they be red or blue shifted? BTW, how did the cop catch up to you? Maybe thru a worm hole?
What's the penalty for breaking the speed of light law?
Why not hydrogen in the "tars" instead of helium. It's much lighter.
Old May 30, 2004 | 09:48 AM
LameRandomName's Avatar
Originally posted by Socrates
If you’re traveling at the speed of light and the guy behind you also traveling at the speed of light flashed you, you will indeed see him flashing you... The speed of light is the only true physical universal constant.
Actually, you wont see him flash you because in order for you to SEE his headlights, the light from them would have to travel FASTER than the speed of light.
Also, the speed of light isn't constant. It depends on the medium it's passing through.
Old May 30, 2004 | 09:55 AM
oil pan 4's Avatar
If you had Hydrogen in your tires that would be cool if they blow out and made some sparks. It would be like hiting a land mine.
Also, Humans arn't ready to travel at, or faster than C.
Old May 30, 2004 | 10:15 AM
dmanc93's Avatar
it is physically impossible to go the speed of light.....period, the best we can do is like 99.99999999%
dan
Old May 30, 2004 | 11:46 AM
Mindgame's Avatar
Never really thought about that Jon but it makes perfectly good sense. Thanks for the perspective.
But wait, there's more! (yeah, I watched an infomercial a few minutes ago )
Dug this up on NASA Aeroquiz...
Q: According to U.S. Federal Aviation Regulations (Part 25.733e, to be exact), any tires mounted on braked wheels for airplanes heavier than 75,000 pounds must be inflated with dry nitrogen or other gases shown to be "inert." What's wrong with using ordinary air?
A: Well, the phrase "inert" gas says it all. When you see the pictures of the white-hot brakes at the rejected takeoff test, when you know that the tires are made of rubber and so could burn, when you know that the tires will let go their gas content in the process, as a cooling measure, you sure prefer to have them inflated with something that will not promote fire at all.
Although they are rare and used only during emergency landings, maximum effort stops can result in very hot brakes. It is not impossible for grease, oil, or the tires to smolder on such a landing, and the last thing anyone would want would be air from a burst tire to feed the fire.
Interestingly, engineers design thermosensitive fusible plugs to be used near the wheel spit that safely vent the tire pressure if the local temperature reaches a predetermined level.
As stated in the regulations, the gas used to inflate the tires must be dry, since ambient temperatures at cruising altitudes are very cold. A chunk of ice, even a small one, inside a tire can throw the wheel off balance during landing. Carbon dioxide, for this reason, is also a poor choice for an inflation gas.
Dry nitrogen is desirable for other reasons as well. It does not promote rust and it will not oxidize the rubber compounds inside the tire.
Contrary to many responses to this week's question, nitrogen offers no real weight advantage over ordinary air. The difference in weight between an air-filled tire and a nitrogen-filled tire is very small!
- The Aeroquiz Editor
Interesting.
-Mindgame
