Head conversion pictures
Old Mar 7, 2007 | 01:24 PM
95ttoplt1's Avatar
If any one has some pictures of what needs to be done to convert SBC to LT1 they would be greatly appreciated.
Also since the work to be done(filling oil drain back) is not structural, could an epoxy be used to fill the drain?? Then all that needs to be done is drill the coolant hole in the deck.
Sorry if I am way off base just looking for info.
Old Mar 7, 2007 | 09:37 PM
SStrokerAce's Avatar
Why not just ream the hole to size and shrink or press fit the drainback tube in?
Old Mar 7, 2007 | 09:53 PM
FASTFATBOY's Avatar
Well it depends, If you are using an LT1/4 intake you have to weld up the coolant passages, weld up the intake bolts and re-drill to Lt1 pattern and re-face the intake side of the head in addition to the oil return.
David
Old Mar 8, 2007 | 01:08 AM
95ttoplt1's Avatar
I am using a Vic super E.
I think I am am going to see if CFM is still doing it. Thanks guys.
Old Mar 8, 2007 | 01:11 AM
FASTFATBOY's Avatar
CFM did mine.
David
Old Mar 8, 2007 | 01:12 AM
95ttoplt1's Avatar
Do you mind telling how much??
Old Mar 8, 2007 | 07:23 AM
FASTFATBOY's Avatar
$400
David
Old Mar 8, 2007 | 07:48 AM
95ttoplt1's Avatar
Thanks David!
Old Mar 8, 2007 | 04:07 PM
FASTFATBOY's Avatar
No problemo, glad to help.
David
MadMav
Feb 6, 2015 11:02 PM
chevysam
Jan 16, 2015 07:45 PM
cmdeshon
Dec 12, 2014 10:51 PM
