Has anyone had to adjust rockers while running?
Old May 23, 2004 | 02:55 AM
bunker's Avatar
Just wondering, I've heard this a few times, but I don't know if it makes sense, I've done it aswell but this time I've changed cams & wondering whether I should do this again or not, basicly some people say primarly with Comp R' lifters that its best to adjust them while the car is idling, why wouldn't it be just as good to do it the normal method of adjusting the rocker while its on the base cirle of the cam? I mean you can see if the rocker is on the base circle, this time before adjusting the 8 rockers at the same time I even turned the engine 15* to the left of 12 o'clock & to the right 15* to make sure none of the pushrods would move, bring it back to 12 o'clock, & do the 8 rockers, then turn another 360* & do the rest.
But by turning the engine 15* left & right of 12 oclock & observing the pushrods not moving told me that I'm definetly on the basecirle of each.
So whats to make the adjusting method of when the car is idleing better then doing it when the car is off, each rocker when its on its basecircle?
Matt.
Old May 23, 2004 | 03:08 AM
arnie's Avatar
Using the method noted above, is good/recommended prior to inital startup. After the engine is appropriately warmed up to operating temp, the final adjustment can then be made while running. This will give a more accurate adjustment. More critical, the more extensive, the use of alloy components. Diff but sorta like the piston/bore clearance/sizing. The pistons are sized with the bores cold and obviously not running. However, the intent is to end up with the proper clearance at 'operating temp'. This is why some pistons are noisy upon initial startup.
Geez, when do some of these guys on this forum sleep?
Old May 23, 2004 | 08:37 AM
LameRandomName's Avatar
Well, the best way to adjust a hydraulic cam has traditionally been by ear, while it's running.
Basically, you loosen up a rocker until it starts clattering real good, slowly tighten it again until the clattering stops, then give it an additional 1/4 turn.
Old May 23, 2004 | 11:04 AM
bunker's Avatar
k cool I'll do that, I've been running around without the engine running method & all seemed fine but I'll do it anyways, maybe it'll get a bit quiter
Old May 24, 2004 | 12:24 AM
bunker's Avatar
just did it with car running, much quiter & she still revs to the moon so they aren't overtightened I assume
Old May 24, 2004 | 12:43 AM
OneFlyn95z28's Avatar
Yes I have always had the best luck doing a final adjustment with the car running
Old May 24, 2004 | 04:13 AM
rskrause's Avatar
Moderator
I've never tried this with the engine running and never had any issues related to rocker adjustment. Doesn't oil get all over the place?
Rich Krause
Old May 24, 2004 | 04:37 AM
bowtiepwr's Avatar
Rich Krause
>not if you take stips of cardboard and lay it inside the head most of the oil should get reflected back into the head .
this is how I always adjusted my rockers (I find it hader to do it the otherway)
Old May 24, 2004 | 09:23 AM
JucinGTA's Avatar
Tip: Take a old or a valve cover you have laying around and cut the whole top off, so basically you have a wall on all sides but a hole on the top. Now you can adjust then while they are running and not have a mess all over.
Old May 24, 2004 | 09:35 AM
Rich Krause
Nothing a can of engine cleaner and a garden hose wont fix.
Old May 24, 2004 | 12:56 PM
bunker's Avatar
I prefer doing it with no valve cover, I have a valve cover with holes in it, but when you find zero lash, somtimes you take your hand off it & the nut spins back a bit, & no you don't get oil splashing, I only get a little sprinkle when the engine starts, but so long as its ideling the oil just accumulates on the sides but doesn't splash everywhere, I also have a hydra rev kit which acts as an oil barrier for splashes from the lifter valley if any wanted to spash up.
Matt.
Old May 24, 2004 | 01:32 PM
Hot Rod Hawk's Avatar
oh the memories of waking up in the morning smelling 10w30 buring on 2" headerpipes and the sound of clickety click of the rockers.
Old May 24, 2004 | 02:09 PM
Now you know...
You can shift the powerband slightly up or down by either tighteneing JUST until the clacking stops or by going 1/2 turn past that point. (instead of 1/4)
Old May 24, 2004 | 04:00 PM
arnie's Avatar
Tip: Take any/old valve cover you have laying around and cut the whole top off, so basically you have a wall on all sides but a hole on the top.
I find this to be the better method as well.
Originally posted by LameRandomName
Now you know...
Well, do know...don't see how anyone can accomplish this. You confusing this with flexibilty of solids?
oldschool
Feb 9, 2016 09:21 PM
edman
Jan 25, 2015 02:41 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
