Forged Cranks who makes decent price Forged Cranks?
Re: Forged Cranks who makes decent price Forged Cranks?
Originally Posted by Denny McLain
In the FWIW club........... We were having problems getting past the 450 rwhp mark with my new 398ci combination and were at a bit of a loss. After replacing the TB with a monoblade and trying three sets of injectors, we finally got the bright idea of rechecking the Comp R's lash setting.
The car made 465.77 rwhp today being a red alert polution day and the only change was zero lashing the comp lifters and a bit of tuning. The car still looks like it having mild lifter issues from 6000-7000 and hits the wall around 7300-7400 rpm.
Based upon the feedback from this list..... our own trial and error...... I'm ordering a cam with a tad more duration and the Morel lifters Monday.
Thanks for the information guys. Also.... I have the Howards rods and so far so good. Wonder where I heard about them??
Bret
Originally Posted by LameRandomName
Oh, OK. Thanks.
Machinst -
When you talk about pressure spikes, are you mainly referring to detonation issues?
Machinst -
Well you are saying quite a few real engine shops are using junk then including ours and we have never had a single failure! I never trust people that say crap like this again until they say something that proves they know something pure and simple. Guys like this make our entire industry look bad.
You can get a Sonny Bryant or a Windberg too and have a great crank or you can get the Eagle or SCAT and get some heads, intakes and valvetrain and make some real power. I like american stuff too if you're going to do an expensive high rpm endurance engine etc. but it's basically wasted money when you are trading getting real power producing items for a crankshaft that is tremendous overkill since NONE of these will break on what we are talking about.
It's funny how we have used "junk" Eagle cranks that make over 1200 RHWP and run 8.0s in 3300 pound cars. We also have some hydraulic roller pump gas engines that make almost 600 RWHP and also put serious street miles on their cars and yet they don't have any issues either with Eagle cranks? Tell me, what are we doing wrong?
Originally Posted by MachinistOne
Eagle is junk pure and simple, never seen one out of the box that mic'd out to spec. Only time I ever use them is on a customer supplied deal, and even so I usually convince them to send it back.
Compared to similarly priced cranks out there, yes they are junk...I have measured taper across the journals, out of spec journals, and some that were bent from the factory...hence I do not use them.
I have not had these problems with callies or scat cranks.
I'm not saying YOU are doing anything wrong...just that they do not meet MY standards and so I use higher quality parts...
I'm not saying that they will break at say 500-600hp...Although I have seen a couple snout failures... I just put a scat in a 489 BBC that makes 600hp in a daily driver. And I like the GM cranks too, we use them in our pump gas 750hp 502's.
We did have some Eagle LS1s with slightly large pilot bearing bores but they had a pilot bearing at Eagle to fix this and they were still inside of GM spec. Of course some of the Lunati and Callies first LS1 deals had reluctors falling off and they cost three times as much but they are nicer pieces and lighter. We have sure seen some problems with the Lunati Pro Billet rods and NONE with the Eagles again even though they are less than half the price! I would say it just depends on the particular part. Lunati is supposed to be redesigning that rod now though?
Ford and others have done testing on rods for the Cobra engine that involved extreme cycling and very large loads since they knew the SC engines would be abused and the rod test results between many different brands including Eagle were truly shocking to many in the industry. I'm not saying that 10,000 rpm wouldn't have sorted stuff out more but lets just say the Eagle had some pretty pricey neighbors at the end!
I do get all my cranks etc. as freight on pallets so at least they don't get beat up in a weak box. I DO have a problem with Eagle there and I wish they boxed their cranks with the bigger heavier boxes and insta-pak foam like Callies does. I am considering reboxing them from now on like that whenever I send them out as a single part.
Originally Posted by 1racerdude
Denny could ya post up after a period of time and let me know if they are still making HP.I would appreciate it.
How much mallory did they use to balance it?
Not against them,just don't trust them.
Back to the powder metal rods....
I'm still on the fence... but might be coming down.
I think it's important to remember that factory LT1/LS1 PM rods were not designed with 600hp in mind, so I don't feel that it's fair to compare them to the Howards rod. I do know that a local dirt track race engine builder is using them (Howards) in a "no forged rod" class (don't know the official class name) and they were #2 in that class with no rod failures last time I checked. Dirt engines turn alot of rpm and are notoriously hard on parts. Will be interesting to see how well they perform in these types of racing classes. I don't doubt that the number of users will increase as time goes on.
The failure LR mentioned is interesting, but it wasn't due to the connecting rod material. The fact that the rod deformed on the big end counters the low ductility I imagined of a PM rod.
Many of the other PM "rod failures" I've read about don't seem to be material related either, yet the rod always seems to get the blame. Then again, there is a lot of this that goes on in the hi-po world. Yes, I've seen pictures of some legitimate failures, but they were always in engines that were big on power/abuse and should have been using a high quality forging in the first place.
As I read more about powder metal processing and the testing many aerospace companies are investing in I come to realize that PM is still evolving as a high-strength manufacturing technique. In one article I remember reading comparing forged titanium components to powder metal, a Lockheed engineer was quoted saying that the new powder metal components were, "As strong if not stronger than the original forgings". The technology is fascinating and it's still very much on the advance. I think we will be seeing more high-strength powder metal components engineered to perform specific duties that forgings use to do at a reduced cost.
-Mindgame
-Mindgame
-Mindgame
-Mindgame
My information for most things comes second hand and I seek out the old hard core racers to get their input. I went with a Eagle crank and the Howards rods because the local dirt track crowd was very high on both. As mentioned, these guys turn 8000 rpm plus for extended periods of time and if that crowd is big on um...... they must work. Cause if anyone can tear one up, they can.
Course then they seem to be able to fix um with bubble gum, silicone and rubber bands for the next round.
-Mindgame
-Mindgame
MG, What ya mean when ya say a rod hanging out the side of a block isn't rod related. It wasn't the crank that was hanging out the side.
When they get the selection of the right powder's, the amount's of the each powder,the perfect mixing technique,and the right methods and pressures, down to a science(which probably won't be in my lifetime) I may try some.
Originally Posted by rskrause
In my profession (medicine) I never want to be either the first or the last to embrace a new therapy. Ditto with my hobby.
Rich
Rich
What area of medicine?
