first gen in fourth gen
Old Jan 21, 2005 | 11:22 PM
n20ta2's Avatar
Looking for sites or info on helping my 1st gen engine swap go smoothly in my 95 T/A.Pictures that could give me ideas would be perfect!im swapping a motown blocked 420ci sb in myT/A with ported edelbrock heads a big solid roller and a victor intake and a holly dominator.I know i need to section off the cowl but how about motor mounts ect? Im also going to have to use a vfn 4" ram air hood to clear the carb I guess.thanks for any leads!!
Old Jan 21, 2005 | 11:27 PM
97WS6SCharged's Avatar
Re: first gen in fourth gen
BMR makes a tubular k-member for the swap. Complete with polyurethane mounts and mounting hardware.
http://www.bmrfabrication.com/F-bodyChassis.htm
Old Jan 22, 2005 | 08:30 AM
Fast Caddie's Avatar
Not to hijack your thread ta2, but... how much easier does that 4th gen BBC k-member ease the installation of a BBC into a 4th gen? Does it help solve some of those firewall/tranny tunnel issues? Does is allow some off-the-shelf headers to be used? If it does, then that would definitely be the way to go.
Mmmmm..... a 454 or 500+ CID BBC sounds good with a 4th gen
Old Jan 24, 2005 | 12:15 PM
n20ta2's Avatar
I think you would still need to make custom headers or modify an existing set.Im going SB because I can pull 700 hp out of this combo and use 1 7/8 over the counter Hedman hustler headers,Big blocks are heavy and make to much torque for what im trying to accomplish
Old Jan 24, 2005 | 04:46 PM
Awsome.... I was unaware that there were off the shelf headers available for this swap. I've been planning on a gen1 SBC swap also, but if there was a lot of fab work, especially with the headers, the the BBC swap was the route i would've taken.
700hp will be pretty easy with a 427 or 434 depending on what heads and intake you use. I want to go ***** to the wall and try to pick up some used 15* or SB2s.... or maybe even canted valve heads
Bxlt1
Sep 29, 2015 03:18 PM
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
