FAST, E-Dist, Crank trigger, Cam sync... argh- what do I need?
Old Jan 31, 2004 | 07:12 PM
  #31
madman69's Avatar
Call MADMAN I can give you all the wire colors and schematic. Plus the tricks in syncing the distributor.
Old Feb 3, 2004 | 01:41 PM
  #32
jimlab's Avatar
A couple questions...
I didn't see anyone answer the question about why the MSD stub can't provide both signals required (hi-res for the eDist, low-res for the crank signal to the ECU). Anyone know?
Second question... my coil brackets and harnesses just showed up, and I assumed that the bolts which hold the coils on screw into the brackets themselves, but the holes aren't tapped with threads. The one bolt that I bought ($2.47!) to make sure I knew what size was required is M6 x 1.0 - 20mm. I can just thread the holes with an M6 x 1.0 tap, but it seems a shame to ruin the coating. Anyone know what the deal is here? I would have assumed these things would come ready to install...
Old Feb 3, 2004 | 02:56 PM
  #33
96Z28SS's Avatar
The bolts are to self tap into the hole.
Kind of sucks but thats how they made them.
Rob
Old Feb 4, 2004 | 12:10 AM
  #34
jimlab's Avatar
Tell me about it.
I think I'll just run a tap through them anyway. I'm going to use my own 18-8 stainless fasteners and I don't want to eat up the threads on a bunch of them trying to screw them in.
Old Feb 4, 2004 | 08:11 AM
  #35
Sean94Z's Avatar
I was reading through the DFI Gen7 directiosn online and came across the LT1 section. They had a little * on it and said that "Can be run in sequential with adapter box" .. So, I called DFI to see how this would work. They told me you need to have yoru optispark modified to send a cam and crank signal and there is a company doing it in california called Blood Motorsports .. Anyone ever hear of them? I did a search on google and came up blank..
--Sean
Old May 16, 2005 | 11:40 PM
  #36
Highlander's Avatar
Re: FAST, E-Dist, Crank trigger, Cam sync... argh- what do I need?
reviving
Old May 17, 2005 | 10:20 PM
  #37
1racerdude's Avatar
[QUOTE=Sean94Z]I was reading through the DFI Gen7 directiosn online and came across the LT1 section. They had a little * on it and said that "Can be run in sequential with adapter box" .. So, I called DFI to see how this would work. They told me you need to have yoru optispark modified to send a cam and crank signal and there is a company doing it in california called Blood Motorsports .. Anyone ever hear of them? I did a search on google and came up blank..
--Sean[/QUOTE
I talked with them about doing mine. Seem like good people,but wasn't going to pay $500.00 to have it done. Tad spendy in my book.
I have their number here somewhere if you need it,finding it is another story.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Chevyguy358
Jan 28, 2015 08:04 PM
birdblack
Dec 30, 2014 06:59 PM
