fabricating longer runner LT1 intake manifold
Re: fabricating longer runner LT1 intake manifold
Originally Posted by jerminator96
Have you had any experience with it? I'm thinking about going with SolidWorks, not sure yet. I'd love to design a new intake manifold for my LT1, maybe I could get Bret to build it for me. As i've said before, my welding skills are limited.
Jeremy
Jeremy
Originally Posted by confused327
not much, you can get a free 30 day trial from their website. most of my cad experience was on autocad '95 lite at school.
What throttle body are you running? I had the same issue when running a 52mm on my 383 turning similar RPM. The issue was cured by the AS&M monoblade where my MAP stayed at 99-100kpa until the limiter at 7000.
Steve
Hey Steve, I have a Monoblade sitting in my garage. I bought it about a month ago, just havent had anytime to install it. Let me know what you have in mind, or when you would need it. I would be curious to see the before and after results myself. Do you have any pics of your 4" CAI? Let me know what you want to do.
Nick
Nick
I might have to download it to try it out. Did they even have 3 dimensional modeling in '95?
I have a sheet metal intake with six inch runners. If someone can host the image I'll e-mail it so everyone can have a peek. The car gained 47 RWT @ 3000 rpm making more power everwhere until 6100 were it lost 20 some @ 7000 rpm. In the process of recamming the car to compensate and push the powerband back up some.
FYI.....I'm using a ASM monoblade for the TB.
it did, i was just really bad at it. my class was all 2d drawing. i just looked up tutorials online to get the idea because i finished the class 3 weeks early and was bored.
I have a friend who is going to give me autocad '07 and solidworks '04, if I ever get around to designing a manifold I'll post pics on here. Maybe someone will think it's worth building.
Jeremy
www.imageshack.com
free hosting
David
Originally Posted by Guss_B
Isn't that intake pictured in the car on the first page a modified gm ram jet 350 intake?
Thats what it started as, would have been cheaper just to get a full blown sheetmetal done.
David
I know the feeling, I finished my cad class early in highschool and spent a month "carving" a LeMans car out of a solid block on AutoCad 2000.
Jeremy
Jeremy
Here's a pic of the 4" CAI. It's probably overkill but at least it's one less thing to worry about. You can see I ditched the MAF with a speed density tune as well to further eliminate any restriction possibility
Steve
Steve
The only thing left that is Ram Jet is the port flanges and injector holes.
Steve
Steve
I'm running a 6" diameter X 9" long cylindrical K&N with a 4" inlet. I should have pretty god flow with that. It's about all I could get crammed in the fenderwell while keeping all of the inner fenderwell plastic intact. I forget the calculations but the K&N should be plenty big enough for the 355 @ 6800.
also,
"Hey Steve, I have a Monoblade sitting in my garage. I bought it about a month ago, just havent had anytime to install it. "
I'll need to take a look at what it will take to open up my twin 58MM bores in the intake manifold to fit a ASM monoblade.
also,
