Engine Swap: Possible or not --Please Help!!!
Old Oct 27, 2007 | 09:32 PM
donlevee32's Avatar
Exclamation Engine Swap: Possible or not --Please Help!!!
I just bought a 1993 Camaro that originaly had a 3.4 v-6 in it. I would like to know if it is possible to drop on earlier (70's) 350 v-8 down in it. All the article that I see either show a LT1 or LS1 engine and no carbuerated engines. It looks like it is a little tighter than the 1988 Camaro that I used to have along with the cab forward design. Please help.
Old Oct 27, 2007 | 09:34 PM
dangalla's Avatar
you will have to do some work to the cowl to fit the carb but it is def possible
Old Oct 27, 2007 | 09:45 PM
donlevee32's Avatar
Thank You Dangalla for the info. I will cut the hood or buy a new one. What concerns me is the location of the distributor?
Old Oct 27, 2007 | 10:17 PM
n20ta2's Avatar
Not the hood but the windshild cowl will need to be cut.You may also need a cowl hood for carb clearence.Distributer will fit,im running an msd pro-billet with an extre large msd ford style adapt a cap on top
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
