Engine block question
Old Jul 10, 2002 | 09:37 PM
  #16
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by strokedTA:
COOL, Rich, Now I have an EXOTIC Race set-up! LOL
Really simple actually.
Dave Brown
</font>
Hey Dave: I'd like to know more about your setup (and the logic behind it)!
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Jul 11, 2002 | 05:18 AM
  #17
Curt (pres AAMC & ZAA)
Guest
Posts: n/a
Question
So what I'm hearing in this thread, it's worthless for me to convert to a studed narrow register straight 4 bolt main with billet caps over a studed two bolt? And the only 4 bolt conversion that's worth the trouble is splayed?
I was going to go to the straight 4 bolt main conversion since it is considerably cheaper than the splayed 4 bolt because they won't have to remachine the registers. I guess I need to think about this some more before I take the block to the machinist.
Old Jul 11, 2002 | 07:52 AM
  #18
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by Curt (pres AAMC & ZAA):
</font>
You could argue that there's no need to use anything other than the stock 2-bolt caps on most buildups. But 4-bolt caps will be a lot stronger. I doubt that the incremental advantage of splayed v. straight caps is of any signficance except for the most extreme buildup. FWIW I am making 733rwhp on straight nodular iron caps.
Rich Krause
"1FASTZ28"
Old Jul 11, 2002 | 02:25 PM
  #19
Soma07's Avatar
Thumbs up
<font face="Verdana, Arial" size="2">Originally posted by Eric Bryant:
All depends - can you hit the same clamping force that was used when the block was originally line-bored? If so, nothing really changes and you don't need to hone the block.
On the other hand, if the cap clamping force changes due to the change from bolts to studs, then it's not a bad idea to clean things up with a quick hone of the mains.
</font>
Thanks Eric!
So I guess its a "try it and see" sort of thing. I guess you would just measure the diameter of the hole to see if its still round after converting to studs?
Thanks,
Jason
Old Jul 12, 2002 | 11:28 AM
  #20
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Wink
Rich, What would you like to know?
I thought most people here knew what I had?
The Logic????
Well, for one, I saved over $5000.00 going with a carb.
Where do you think that extra money went?
If I was boosted or drove it more on the street, EFI would "maybe" be a better option, but with spray it's not a major benefit.
Dave Brown
If a little's good,
More is better,
And too much is just right!!!
Old Jul 12, 2002 | 01:08 PM
  #21
rskrause's Avatar
Moderator
Post
The Logic????
Dave Brown
</font>
You told me what I needed to know (that it's a race setup with a carb). FWIW that makes it "exotic" in my lexicon! For 99.999% of "the rest of us" street and street/strip guys keeping the LT1 with EFI makes more sense.
Rich Krause
"1FASTZ28"
Old Jul 16, 2002 | 03:46 PM
  #22
Matt Mc's Avatar
Post
Hey Rich
You said that you were making over 700 RWHP on iron caps. So is your set up a factor 2 bolt or 4 bolt bottom end?
Matt mc
Old Jul 27, 2002 | 01:42 PM
  #23
Matt Mc's Avatar
Post
Old Jul 31, 2002 | 04:43 PM
  #24
Jerm93z28's Avatar
Post
</font>
you saved $5,000 by going to a carb!?!? how so?
jeremy
'93 z28 m6 (Purple Pearl Metallic)
stock shortblock, 230/236 cam, mildly ported heads, hooker longtubes, csi waterpump, all the usual bolton stuff.....
7.98 @ 88.7mph 1.84 60' (1/8mi)
Old Jul 31, 2002 | 06:40 PM
  #25
KTamez's Avatar
Post
Take my Scenario:
$350 LT4 Intake
$300 Porting
$2000 FAST
$500 Injectors
$500 Throttle Body
$100 Fuel Pump
$500 Laptop
$100 Regulator
$275 Opti
$4625 Total
or
$350 Single Plane Intake
$300 Porting
$200 Machining for LT1 Bolt Pattern (Just a guess)
$1000 Carb
$300 Fuel Pump (Not counting new braided lines etc, since OEM can't be used)
$100 Regulator
$200 Distributor
$2650 Total
Note that not everyone might need that $2000 FAST system.
I'm sure I'm missing some things, but when it comes down to it, if you have a perfectly good LT1 setup, its hardly worth going to a carb. Consider you wouldn't need to buy the intake, Opti, and a few other items.
No doubt Dave's personal scenario is slightly different, being a Gen1 SBCbut I think he's pretty well overexagerating there at $5k.
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Jul 31, 2002 | 10:57 PM
  #26
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by Matt Mc:
Hey Rich
Matt mc
</font>
Factory 2-bolt converted to 4-bolt using GM straight nodular iron caps pn 3932482. It's what my engine builder reccomended so I went with them. No problems so far, though my setup is not a high-revver (6K rpm redline).
Rich Krause
"1FASTZ28"
Old Nov 7, 2002 | 09:24 AM
  #27
Jim S. '95 Z28's Avatar
Was this more of a budget issue or a means of averting "stretch" with billet caps?
Old Nov 7, 2002 | 12:56 PM
  #28
Faccnator's Avatar
strokedTA,
I have a carbed going into my 95 camaro in about two weeks. We are just going to tackle all the problems (cowl clearance, accessories, etc.....) as we get there but if you have done it any suggesstions or pics would be great.
Faccnator
Old Nov 7, 2002 | 06:26 PM
  #29
rskrause's Avatar
Moderator
He never really gave me much of a reason. Maybe he had a set laying around? He is sort of opinionated and I went along with it. All I can say is, it works!
Rich Krause
F'n1996Z28SS
Aug 23, 2023 11:19 PM
willismoons
Feb 14, 2015 08:42 PM
Jul 4, 2005 05:00 PM
squirrels
Jul 13, 2002 01:58 AM
