EGT readings around 1250 at WOT.
Old May 2, 2003 | 02:05 PM
xxsaint69x's Avatar
Hey guys, got my EGT guage hooked up to #1 primary about 2 inches from the head. I am getting readings of around 1250 at WOT, i was wondering if i am goin to see any gains at all if i get my Temperature to around 1450ish. How would i go about adjusting the values on my PE table to raise the temp up a litte bit? The car has stock heads and a CC306 Cam.
Posting it here since no one has a clue about EGT reading in the LT1 section.
Marcin
Old May 5, 2003 | 03:05 PM
TheNovaMan's Avatar
It sounds like you're running rich. If you optimize the A/F ratio, the EGT will come up to around 1450 like you said, and you should find some power. I have no idea how to adjust the PE table though.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
1BadRS
Apr 15, 2002 11:36 AM
