EFI Intake Plenum?
Old Nov 23, 2003 | 09:09 PM
mastrdrver's Avatar
EFI Intake Plenum?
Does the size of the area where the air is pulled into the runners, plenum?, have a direct effect on power? Do you want it as small as possible, and would groves in the base allow for better air distribution at higher rpms?
Jeremy
Old Nov 24, 2003 | 01:44 PM
Z28tt's Avatar
You want a fairly decent volume. I think the rule of thumb was about 1/2 of the displacement (I forget, and I'm sure someone will correct me). It acts as a reservoir for the air in between "Events" - i.e. Intake Valve 1 opens, draws air from the plenum, then 90 degrees later, Intake Valve 8 opens. If the plenum is too small, the airflow through the throttlebody will be pulsing with each event, rather than a steady (more efficient) flow into the plenum, where each runner can take air. There's been quite a bit of home-brew engineering with the LT1 and GrandNational guys playing with larger plenum volumes...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
TT350
Mar 31, 2015 07:44 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
