effects of offset cam bushing on LT1
Old Aug 7, 2006 | 07:43 AM
  #16
Re: effects of offset cam bushing on LT1
Originally Posted by 1racerdude
A '93-'94 being driven from the center will not move the opti as much.
They are also batch fire which wouldn't effect the injectors as much.
I specifically asked about a 1994 shaft driven Opti, not a 93/94. I know the 93 is batch fire - that's why I did not include it. You surely know the 1994 is full sequential.
Old Aug 7, 2006 | 07:46 AM
  #17
I think the whole issue of injector timing is blown way out of proportion, particularly with the typical application where people are knowingly pushing the injectors toward 100% DC.... they're open almost all the time... what difference will it make if the indexing of the cam to TDC is off by a degree or two.
Old Aug 7, 2006 | 11:13 AM
  #18
1racerdude's Avatar
Ya are right again. '94 IS sequential.Isn't the '93 also spline driven.
Old Aug 7, 2006 | 11:49 AM
  #19
thesoundandthefury's Avatar
In leiu of this statement:
What is the relevance of this question?:
Just to see who's paying attention.... is the answer to the original question the same for both a 94 with the Opti driven off the cam sprocket and a 95-97 with the Opti driven off the cam dowel?
Old Aug 7, 2006 | 04:09 PM
  #20
The relevance is that it affects the answer to the original question. What is true about the 95-97 dowel driven cam/TDC/Opti relationship being independant of whether you use a bushing or an offset key, it not true for a 94 (and yes, the 93 is also driven off the sprocket).
Fred, as has been explained in the archives, it is helpful to visualize what is taking place. I have not seen how the '94 is assembled, so I'll explain it in a roundabout way.
I know the answer.... I've visualized it . The 94 cam does not drive the Opti directly. The connection is from splines on the cam sprocket to the Opti. If a dowel bushing is used to move the cam, the position of the Opti, relative to TDC does not move. If you use an offset key, the relationship between the Opti and the crankshaft is altered.
On a 95-97, the dowel drives the Opti, and using a bushing or an offset key will alter the indexing of the Opti to TDC.
You also need to visualize WHY you are moving the cam. If you move the (correctly ground) cam to intentionally advance it or retard it, you have altered the relationship of TDC to the Opti. If you move the cam to CORRECT centerlines that are not ground correctly with reference to the dowel, you are "correcting" the relationship of the cam to TDC, and "correcting" the indexing of the Opti to TDC.
Old Aug 8, 2006 | 11:17 AM
  #21
Fred,
In regards to the mechanical differences between a spline driven opti vs. a dowel driven opti and how an offset bushing effects either I'm in complete agreement with you. But can we also agree on one other point? That when we're indexing a cam to TDC, how we index the Opti in relation to that is for the purpose of spark timing accuracy and NOT for fuel timing accuracy?
Old Aug 8, 2006 | 02:51 PM
  #22
1racerdude's Avatar
Fred,
The opti controls the injectors too.
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
